@reflector absolutely right))
I’m thinking to connect WAN port of mt300n-v2 with LAN of B1300 and setup PPPoE on MT300. I want to use B1300 as main router. Will it help?
And one more about Next DNS and B1300.
Few times ago i was tried to install this script. Installed the latest beta (3.104).
Output:
root@GL-B1300:~# sh -c “$(curl -sL https://nextdns.io/install)”
sh: .: line 948: can’t open ‘/etc/os-release’
ERROR: Unsupported OS: Linux
ERROR: Unknown bin location for
INFO: OS:
INFO: GOARCH: armv7
INFO: GOOS: linux
INFO: NEXTDNS_BIN:
INFO: LATEST_RELEASE: 1.6.4
ERROR: Cannot detect running environment.
Perhaps this happens because /etc/os-release don’t exist? Please, correct ))
@mitron
that won’t work because the architecture isn’t recognised by the automated installer script. you can however, since B1300 is based on armv7 to get the binary files here and put them
in the router to run it.
@realjohny
similar situation if you want to run AdGuardHome on the router, i have an ar750s running this and i am using the linux_mips binary. B1300 should work with linux_arm.
Followed instruction on the page to install NextDNS on B1300
Got same error. How you put file into the router? Using WinSCP ? Can you please guide where to copy and command to run it.
Which file here should be copies and run for B1300? Can you please guide.
Will it via WinSCP and SSH later?
For use of ssh and scp, pls refer to
No that is not the issue in fact.
Can you please guide how to ?
Should I follow …>
I have firmware 3.104 on my GL-AR750S-Ext (Slate), but I don’t see these NextDNS options.
I assume it’s coming to other models as well?
I see it’s included in OpenWRT as of 19.07.01
NextDNS only works with openwrt 1907.
For AR750s we do not have openwrt 1907. There is a problem with big kernel and we are still trying to find a solution.
is it possible to update Openssl to >1.1.1?
then Stubby can work with it
I think so. We are also upgrading openvpn to 2.5 which need openssl 1.1.1.
Working on it.
cool. can get Stubby and unbound updated together with Openssl
