I have a gl-mv1000 and I would take the advantages of nginx (I need to reverse proxy some server in the lan, later i will use luci-app-acme package to get letsencript certificates for those web servers an the router DDNS name itself… but this is a next step).
I successfully moved lighttpd listen port from 80 to 88 editing the /etc/lighttpd/lighttpd.conf file
then installed luci-ssl-nginx package and configured nginx on port 80 as proxy for lighttpd server. The /etc/nginx/nginx.conf file is as simple as:
user root;
worker_processes auto;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
access_log off;
server {
listen 0.0.0.0:80 default_server;
server_name _;
location / {
proxy_pass http://localhost:88;
but I don’t like this solution because I get the web interface both at port 80 and 88 (of course firewall could help) while I would completely get rid of lighttpd and serve pages using nginx.
When installing luci-ssl-nginx (or luci-nginx for not https redirect) package it configures a more complex nginx.conf which serves the luci interface correctly but the advantages of gl.inet customized interface is lost.
I can set idx_vue.html as default index page but then it is not working, just asking language selection and new password.
I suppose it is because the cgi server not configured but don’t know how to do.
(in the lighttd configuration there is a /api location but could not do the same working in the nginx config)
