No 5Ghz wifi after 4.4.6 upgrade (fixed)
Edit: I managed to fix it myself and have info which may be of use to others.
After installing the 4.4.6 upgrade your 5G wifi card in the router changes its default country code to US. This is incorrect for my location and after manually correcting it I got 5Ghz wifi back!
Hi @GrannySmasher , it also happened to a few others. Thanks for sharing your fix!
