I’ve installed the FW openwrt-axt1800-kernel5.4 and everything looks good. Except I can’t find the -5G SSID … Okay, the Slate AX was pretty far away.
Now I’m sitting 20cm next to it, still no -5G
The admin interface at https://192.168.8.1 shows everything is fine:
But ssh says ‘no, no SSID’:
ApNos-f0622cca-devel
OpenWrt 21.02-SNAPSHOT, r16399+142-c67509efd7
root@GL-AXT1800:~# iwinfo
wlan0 ESSID: unknown
Access Point: 00:03:7F:xx:xx:xx
Mode: Client Channel: unknown (unknown)
Center Channel 1: unknown 2: unknown
Tx-Power: 0 dBm Link Quality: unknown/70
Signal: unknown Noise: -103 dBm
Bit Rate: unknown
Encryption: unknown
Type: nl80211 HW Mode(s): 802.11nacax
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: yes PHY name: phy0
wlan1 ESSID: "GL-AXT1800-38b"
Mode: Master Channel: 6 (2.437 GHz)
Center Channel 1: 6 2: unknown
Tx-Power: 20 dBm Link Quality: unknown/70
Signal: unknown Noise: -100 dBm
Bit Rate: unknown
Encryption: WPA2 PSK (CCMP)
Type: nl80211 HW Mode(s): 802.11bgnax
Supports VAPs: yes PHY name: phy1
WAN is provided via ethernet cable.
Should I dig a little deeper, or will there be another image, soon?
