I just receive this GL-MT300N-V2, I both on Amazon…
Out of the box…
Once it is all plugged LAN, WAN and power…
The SSID GL-MT300N-V2-xxx doesn’t appear in my wifi list on my computer…
On the box it said to try to connect to the router with a browser at 192.168.8.1.
This router does not seem to work…
I have tried to scan this small nekwork using Angry IP scan…
The only hit I get is My computer at IP 192.168.1.11, usually the router should be listed at 192.168.1.1, but no!
Some thing is wrong with this device…
I believe I got a bad one…
I have try the reset and button nothing has change…
Do you have any idea what I could try?
