No connection to Nord VPN servers
Hello and good evening,
I hope someone can help me. I updated the firmware of my GL-MT300N-V2 to version 4.3.18. I can log in to NordVPN without any issues. However, when I try to connect to a server, it fails to establish a connection. Does anyone know why this might be and have any tips?
Thu Dec  5 15:33:25 2024 daemon.notice ovpnclient[27788]: VERIFY EKU OK
Thu Dec  5 15:33:25 2024 daemon.notice ovpnclient[27788]: VERIFY X509NAME OK: CN=de1076.nordvpn.com
Thu Dec  5 15:33:25 2024 daemon.notice ovpnclient[27788]: VERIFY OK: depth=0, CN=de1076.nordvpn.com
Thu Dec  5 15:33:26 2024 daemon.notice ovpnclient[27788]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Thu Dec  5 15:33:26 2024 daemon.notice ovpnclient[27788]: [de1076.nordvpn.com] Peer Connection Initiated with [AF_INET]194.233.96.59:443
Thu Dec  5 15:33:27 2024 daemon.notice ovpnclient[27788]: SENT CONTROL [de1076.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Thu Dec  5 15:33:27 2024 daemon.notice ovpnclient[27788]: AUTH: Received control message: AUTH_FAILED
Thu Dec  5 15:33:27 2024 daemon.notice ovpnclient[27788]: SIGTERM[soft,auth-failure] received, process exiting
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_lan (safe_mode_lan) is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_guest (safe_mode_guest) is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_mark (safe_mode_mark) is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_mark_save (safe_mode_mark_save) option 'extra' is not supported by fw4
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_mark_save (safe_mode_mark_save) is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section safe_mode_mark_drop (safe_mode_mark_drop) is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section @forwarding[0] is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section @forwarding[1] is disabled, ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section nat6 option 'reload' is not supported by fw4
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section gls2s option 'reload' is not supported by fw4
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section glblock option 'reload' is not supported by fw4
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_guest/01-forward_bypass_domain.nft'
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_lan/01-forward_bypass_domain.nft'
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Thu Dec  5 15:33:29 2024 daemon.notice netifd: ovpnclient (27948): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Thu Dec  5 15:33:32 2024 daemon.notice netifd: ovpnclient (27948): DROP  all opt -- in * out *  0.0.0.0/0  -> 0.0.0.0/0   match-set GL_MAC_BLOCK src
Thu Dec  5 15:33:32 2024 daemon.notice netifd: Interface 'ovpnclient' is now down
Thu Dec  5 15:33:36 2024 user.notice mwan3[28198]: Execute ifdown event on interface ovpnclient (unknown)
Thu Dec  5 15:33:41 2024 user.notice firewall: Reloading firewall due to ifdown of ovpnclient ()
Please make sure you use the right credentials, they are different from login.
See Changes to the login process on third-party apps and routers – Live Chat, VPN Setup, Troubleshooting | NordVPN Customer Support
