I have an AR300M who worked like a charm for more than one year with NordVPN.
But since yesterday I have no internet access on it even when I disconnect the VPN.
My configuration is like that : Apple TV > AR300M > modem everything linked through ethernet (DHCP).
I already try the followings :
another port on the modem
another cable
factory reset the router (version 2.27 by the way)
try different mode router/bridge/repeater
try the tool diagnostics and I have the following results :
PING lede-project.org (139.59.209.225): 56 data bytes
64 bytes from 139.59.209.225: seq=0 ttl=59 time=10.102 ms
64 bytes from 139.59.209.225: seq=1 ttl=59 time=7.187 ms
64 bytes from 139.59.209.225: seq=2 ttl=59 time=8.955 ms
64 bytes from 139.59.209.225: seq=3 ttl=59 time=6.176 ms
64 bytes from 139.59.209.225: seq=4 ttl=59 time=7.933 ms
— lede-project.org ping statistics —
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 6.176/8.070/10.102 ms
Looks fine to me but when I am connected on the router I am not able to go on the internet.
With my mac I have the following results : Sent packets 36.992.008 received packets : 18.157.122.
Everything else on my network works fine.
I am really lost guy, this things make me crazy.
Please note that I have really really limited network knowledge.
Yes I also thought that it’s coming from Nord but I disabled openvpn on the router and still no internet access (I also perform a test with my Mibox and nordvpn is working).
Here is the log :
Sun Feb 17 08:12:29 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:12:29 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:12:29 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:12:29 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:12:29 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:12:59 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:12:59 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:12:59 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:12:59 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:12:59 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:13:29 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:13:29 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:13:29 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:13:29 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:13:29 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:13:59 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:13:59 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:13:59 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:13:59 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:13:59 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:14:29 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:14:29 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:14:29 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:14:29 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:14:29 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:14:59 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:14:59 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:14:59 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:14:59 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:14:59 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:15:24 2019 daemon.info odhcpd[1591]: Using a RA lifetime of 0 seconds on br-lan
Sun Feb 17 08:15:29 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:15:29 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:15:29 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:15:29 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:15:29 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:15:59 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:15:59 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:15:59 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:15:59 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:15:59 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:16:30 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:16:30 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:16:30 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:16:30 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:16:30 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:17:00 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:17:00 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:17:00 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:17:00 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:17:00 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:17:30 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:17:30 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:17:30 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:17:30 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:17:30 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:18:00 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:18:00 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:18:00 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:18:00 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:18:00 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:18:30 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:18:30 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:18:30 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:18:30 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:18:30 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:19:00 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:19:00 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:19:00 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:19:00 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:19:00 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:19:30 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:19:30 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:19:30 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:19:30 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:19:30 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:20:00 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:20:00 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:20:00 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:20:00 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:20:00 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:20:30 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:20:30 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:20:30 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:20:30 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:20:30 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:21:00 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:21:00 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:21:00 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:21:00 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:21:00 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:21:31 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:21:31 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:21:31 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:21:31 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:21:31 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:21:34 2019 daemon.info odhcpd[1591]: Using a RA lifetime of 0 seconds on br-lan
Sun Feb 17 08:22:01 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:22:01 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:22:01 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:22:01 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:22:01 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:22:31 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:22:31 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:22:31 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:22:31 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:22:31 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:23:01 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:23:01 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:23:01 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:23:01 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:23:01 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:23:31 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:23:31 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:23:31 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:23:31 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:23:31 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:24:01 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:24:01 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:24:01 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:24:01 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:24:01 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:24:31 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:24:31 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:24:31 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:24:31 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:24:31 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:25:01 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:25:01 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:25:01 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:25:01 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:25:01 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:25:31 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:25:31 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:25:31 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:25:31 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:25:31 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:26:01 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:26:01 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:26:01 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:26:01 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:26:01 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:26:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:26:32 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:26:32 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:26:32 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:26:32 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:26:32 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:27:02 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:27:02 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:27:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:27:02 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:27:02 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:27:32 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:27:32 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:27:32 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:27:32 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:27:32 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:28:02 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:28:02 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:28:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:28:02 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:28:02 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:28:32 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:28:32 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:28:32 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:28:32 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:28:32 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:29:02 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:29:02 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:29:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:29:02 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:29:02 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:29:32 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:29:32 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:29:32 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:29:32 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:29:32 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:30:02 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:30:02 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:30:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:30:02 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:30:02 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:30:32 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:30:32 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:30:32 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:30:32 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:30:32 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:31:02 2019 daemon.info odhcpd[1591]: Using a RA lifetime of 0 seconds on br-lan
Sun Feb 17 08:31:02 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:31:02 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:31:02 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:31:02 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:31:02 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:31:33 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:31:33 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:31:33 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:31:33 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:31:33 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:32:03 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:32:03 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:32:03 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:32:03 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:32:03 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:32:33 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:32:33 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:32:33 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:32:33 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:32:33 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:33:03 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:33:03 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:33:03 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:33:03 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:33:03 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:33:33 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:33:33 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:33:33 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:33:33 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:33:33 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:34:03 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:34:03 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:34:03 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:34:03 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:34:03 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:34:33 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:34:33 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:34:33 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:34:33 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:34:33 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:35:03 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:35:03 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:35:03 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:35:03 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:35:03 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:35:33 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:35:33 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:35:33 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:35:33 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:35:33 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:36:03 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:36:03 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:36:03 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:36:03 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:36:03 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:36:04 2019 daemon.info odhcpd[1591]: Using a RA lifetime of 0 seconds on br-lan
Sun Feb 17 08:36:34 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:36:34 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:36:34 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:36:34 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:36:34 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:37:04 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:37:04 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:37:04 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:37:04 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:37:04 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:37:34 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:37:34 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:37:34 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:37:34 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:37:34 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:38:04 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:38:04 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:38:04 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:38:04 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:38:04 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:38:34 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:38:34 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:38:34 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:38:34 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:38:34 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:39:04 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:39:04 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:39:04 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:39:04 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:39:04 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:39:34 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:39:34 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:39:34 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:39:34 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:39:34 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:40:04 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:40:04 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:40:04 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:40:04 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:40:04 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:40:34 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:40:34 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:40:34 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:40:34 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:40:34 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:41:04 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:41:04 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:41:04 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:41:04 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:41:04 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:41:35 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:41:35 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:41:35 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:41:35 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:41:35 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:42:05 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:42:05 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:42:05 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:42:05 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:42:05 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:42:35 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:42:35 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:42:35 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:42:35 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:42:35 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:43:05 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:43:05 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:43:05 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:43:05 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:43:05 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:43:35 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:43:35 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:43:35 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:43:35 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:43:35 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:43:46 2019 daemon.info hostapd: wlan0: STA 2c:f0:ee:0c:e5:de IEEE 802.11: authenticated
Sun Feb 17 08:43:46 2019 daemon.info hostapd: wlan0: STA 2c:f0:ee:0c:e5:de IEEE 802.11: associated (aid 1)
Sun Feb 17 08:43:46 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 2c:f0:ee:0c:e5:de
Sun Feb 17 08:43:46 2019 daemon.info hostapd: wlan0: STA 2c:f0:ee:0c:e5:de RADIUS: starting accounting session 80D424C61AF9CC58
Sun Feb 17 08:43:46 2019 daemon.info hostapd: wlan0: STA 2c:f0:ee:0c:e5:de WPA: pairwise key handshake completed (RSN)
Sun Feb 17 08:43:46 2019 daemon.info dnsmasq-dhcp[10928]: DHCPREQUEST(br-lan) 192.168.8.179 2c:f0:ee:0c:e5:de
Sun Feb 17 08:43:46 2019 daemon.info dnsmasq-dhcp[10928]: DHCPACK(br-lan) 192.168.8.179 2c:f0:ee:0c:e5:de Vincents-Air
Sun Feb 17 08:44:05 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:44:05 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:44:05 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:44:05 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:44:05 2019 daemon.info gl-health>>: Everthing is OK!!!
Sun Feb 17 08:44:35 2019 daemon.info gl-health>>: AP Ok=1
Sun Feb 17 08:44:35 2019 daemon.info gl-health>>: network(caIfnames) = wan wan6 wwan
Sun Feb 17 08:44:35 2019 daemon.info gl-health>>: check wpa runing =
Sun Feb 17 08:44:35 2019 daemon.info gl-health>>: STA Ok=1
Sun Feb 17 08:44:35 2019 daemon.info gl-health>>: Everthing is OK!!!
I also tried V3 and still the same issue : the router is able to go on the internet (I am able to ping facebook.com for example through luci) but when I connect my mac or my apple TV on the wifi of the router I am not able to go on the internet with my mac or my Apple TV (when they are connected on the wifi of the modem no issue obviously).
Edit : problem solved
I just updated my Apple TV and it’s working, it’s still not working on my mac but it does work with the mac of my girlfriend which is updated to the latest macOS version.
