No Internet Connection! in display and GUI when connection is LTE
On 3 modems and with firmware (3.100 through to 3.211) I get the message
“No Internet” on the LED Display and also “No Internet Connection! Find new networks to reconnect.” within the LUCI web GUI, however LTE connectivity works and I can surf the web. This does not occur when the router is in repeater mode, just on cellular.
This occurs with the following devices
Mudi (GL-E750)
Amarok (GL-X1200)
This happens on various carriers and with firmware (3.100 through to 3.211) only on LTE.
I have te same problem with my mango. when connecting to home wifi, i have internet. when i connect through SIM-USB-Router Huawei E5567(wifi) i have no internet.
I upgraded latest firmware, restarted , no luck.
please let me know if you found a solution.
The GL-MT300N Mango with separate Huawei E5576 LTE wifi hotspot is a bit different setup from the GL-E750 Mudi and GL-X1200 Amarok, both of which have built-in LTE modems.
Can you post a screenshot of the full Admin Panel → Internet webpage that shows all the connections to the Internet?
This seems a different story. Have you changed Huawei or GL router’s subnet to others because both use 192.168.8.1 by default.
Yes I did change the default subnet. So are you saying that the router is using a hard coded subnet in the script to detect connectivity?
Not that I had no issues previously.
I believe the subnet comment was for karim, whose GL-MT300N Mango and Huawei E5576 is different than your GL-E750 Mudi and GL-X1200 Amarok.
In karim’s setup, the 2 devices cannot have the same default subnet 192.168.8.xxx, or the GL-MT300N cannot route between LAN and WAN.
Pls check if your network disables ping to Google. The router use ping to detect internet connection.
I have disabled internet connection check but the Mudi’s display is still showing “No Internet”. Connection to Internet is okay, no problems, only the display is showing wrong. Any troubleshooting available?
I have the same problem too in the E750. Everything’s working fine, except from the “no internet” connection message in the screen.
@Bpz1970: in Multi-WAN at Cellular I have disabled Internet Status Tracking and the false no Internet disappeared.
Turn this option off.
The issue is fixed by changing the OpenDNS server addresses to some from Google and Cloud flare and by changing the interface priority, placing cellular on top priority.
