No internet connection with PPoE
Hi everyone,
The fiber conneciton has finally been installed and the modem is working fine. For some reason I can't get the Flint 2 to work. I connected the modem to the WAN port and I still don't have a connection.
I attached the logs.
Any help would be greatly appreciated.
Screenshot 2024-08-01 160132
Screenshot 2024-08-01 160431
The more detailed logs:
The log is as follows:
Thu Aug  1 17:00:36 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Thu Aug  1 17:00:36 2024 daemon.notice netifd: Interface 'wan' is setting up now
Thu Aug  1 17:00:36 2024 daemon.info pppd[5712]: Plugin pppoe.so loaded.
Thu Aug  1 17:00:36 2024 daemon.info pppd[5712]: PPPoE plugin from pppd 2.4.9
Thu Aug  1 17:00:36 2024 daemon.notice pppd[5712]: pppd 2.4.9 started by root, uid 0
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: Joining mDNS multicast group on interface eth1.7.IPv6 with address  IPV6-ad.
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: New relevant interface eth1.7.IPv6 for mDNS.
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: Registering new address record for IPV6-ad on eth1.7.*.
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::9683:c4ff:fea2:eb44.
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: New relevant interface eth1.IPv6 for mDNS.
Thu Aug  1 17:00:38 2024 daemon.info avahi-daemon[4333]: Registering new address record for fe80::9683:c4ff:fea2:eb44 on eth1.*.
Thu Aug  1 17:00:41 2024 daemon.info pppd[5712]: PPP session is 1051
Thu Aug  1 17:00:41 2024 daemon.warn pppd[5712]: Connected to IPV6-ad via interface eth1.7
Thu Aug  1 17:00:41 2024 kern.info kernel: [ 5393.208361] pppoe-wan: renamed from ppp0
Thu Aug  1 17:00:41 2024 daemon.info pppd[5712]: Renamed interface ppp0 to pppoe-wan
Thu Aug  1 17:00:41 2024 daemon.info pppd[5712]: Using interface pppoe-wan
Thu Aug  1 17:00:41 2024 daemon.notice pppd[5712]: Connect: pppoe-wan <--> eth1.7
Thu Aug  1 17:00:41 2024 daemon.notice pppd[5712]: peer from calling number  IPV6-ad authorized
Thu Aug  1 17:00:41 2024 daemon.info pppd[5712]: LCP terminated by peer
Thu Aug  1 17:00:44 2024 daemon.notice pppd[5712]: Connection terminated.
Thu Aug  1 17:00:44 2024 daemon.notice pppd[5712]: Modem hangup
Thu Aug  1 17:00:44 2024 daemon.info pppd[5712]: Exit.
LCP terminated by peer means that the modem hung up.
So you will need to check with your ISP. Maybe they have some special things active like you need to tell them your MAC?
Normally with my ISP you don't need to enter the username and Password for PPoE but something went wrong. That was the issue in the end!
