Hi all,
I need support setting up my Slate AX as Wireguard Client. As Wireguard Server I am using my Fritz!Box 7530. With My IPhone I am able to connect via Wireguard to my Fritz!Box.
I have successfully set up a Wireguard Client on the GL.iNet web front. On the GL.iNet as well on the Fritz!Box web frontend the Wireguard Connection is displayed as successfully established but I am not able to establish an internet connection by using the Slate Ax.
At the moment I am at home and the Slate AX is connected to my Fritz!Box in Repeater mode but both networks are using different ip address ranges. My Fritz!Box is using 192.168.178.xxx and my GL.iNet is using the address range 192.168.8.xxx
I have already tried to establish an OpenVPN connection to NordVPN with the Slate AX and this is also working fine.
Any ideas what is going wrong?
It seems to me a dns issue if both are successfully connected. Have changed the DNS settings ? Can you ping the IP of the fritz box from GL box through the tunnel ?
ping to 192.168.178.1 (Connected via MacBook to the GL.iNet with Wireguard connection) is reponsing the following message:
92 bytes from console.gl-inet.com (192.168.8.1): Destination Port Unreachable
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 5400 015c 0 0000 3f 01 3e0b 192.168.8.240 192.168.178.1
ping to 192.168.178.1 (Connected via MacBook to the GL.iNet without Wireguard connection) is reponsing the following message:
PING 192.168.178.1 (192.168.178.1): 56 data bytes
64 bytes from 192.168.178.1: icmp_seq=0 ttl=63 time=6.079 ms
64 bytes from 192.168.178.1: icmp_seq=1 ttl=63 time=6.342 ms
64 bytes from 192.168.178.1: icmp_seq=2 ttl=63 time=7.106 ms
^C
--- 192.168.178.1 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
