No Internet on Flint 2 every morning
I always have an issue similar to this. Most mornings, mine and my wives will complain, that there's no Internet access via Wi-Fi. If I open the GL.iNet app it will show, that there's no Internet access. If I reboot the router, it will work again without problems. I've also noticed, that if I try to open any website on a PC connected via Ethernet, the problems will also be gone.
My setup is simple: a fiber modem from my provider connected to the WAN port on the Flint 2. The WAN port has the MAC address of the previous router, so that it gets a public IP assigned. Phones connect via Wi-Fi, PCs via Ethernet.
Could you please provide additional information as described here?
Thanks! :wave:
  • Device Model: GL-MT6000
  • Firmware version: 4.7.0 (release3)
  • Network topology diagram
  • Problem description - as in first post
  • DHCP server on the GL-MT6000
  • DNS from the ISP
Can you look through the logs if you see something suspicious?
Do you use AdGuard Home by chance?
Unfortunately the logs from today morning are already gone. I will attach check them if it happens again.
No, I'm not using AdGuard Home.
Yeah, logs are gone after reboot - so collect them before :slight_smile:
