Smarley
December 13, 2025, 7:51am
How can I keep the local internet for Guest when the VPN Policy Traffic from Wired LAN and Primary Wi-Fi is selected?
I'm losing the internet on the Guest Wifi.
The same happens with the Primary if I select the rule for only Guest be routed via VPN.
The router is the AXT1800 with the 4.8.2 firmware.
Thank you.
bruce
December 15, 2025, 3:39am
2
We cannot reproduce this issue locally.
LAN (primary WiFi) go to VPN, Guest WiFi go to WAN, without issue:
Guest WiFi go to VPN, LAN (primary WiFi) go to WAN, without issue:
Please confirm whether you have turned off All Other Traffic when setting up tunnel rules.
You need to allow traffic from interfaces outside the VPN rules to access the WAN (such as LAN go to VPN in VPN rule, Guest WiFi go to WAN), and you need to enable All Other Traffic.
To get a closure here.
The issue was the Client, I upgrade it from scratch without keeping the configuration and now it is working again.
system
Closed
June 8, 2026, 12:15pm
6
