If you are connected to VPN server, but can’t access the Internet, it usually causes by VPN server, may your VPN server only allow site to site network, it doesn’t allow the VPN client to access the Internet.
How do you setup your VPN server? Using GL router as well?
No, it’s a VPS under Linux. The problem is that it works well if I plug an internet cable to the WAN port, but it does not work when I use the internal mode.
Meanwhile I’m trying to find a clue here /etc/config/
@kyson-lok, here is what I found in the script # $INTERFACE Name of the interface which went up or down (e.g. "wan" or "wwan") # $DEVICE Physical device name which interface went up or down (e.g. "eth0" or "wwan0")
I guess I need to set these vars, but in what script must I set them?
Is the modem connection reliable?
I had similar issues where the tun interface stays up and the routes get deleted.
I removed Persistent-tun from my config.
