slava
August 5, 2019, 7:43pm
Hello, I’m using GL iNet 4g smart router, firwmare version LuCI openwrt-18.06 branch (git-18.196.56128-9112198)](GitHub - openwrt/luci: LuCI - OpenWrt Configuration Interface ) / OpenWrt 18.06.1 r7258-5eb055306f
I checked the config I use on other machine and it works well.
When I enable my OpenVPN client, internet stops working: e.g. when I ssh to it I can’t ping any IP address. Maybe I need to add something to the iptables rules?
slava
August 5, 2019, 7:46pm
2
I use the wwan0 (the built-in 3g/4g modem) interface to connect the Internet.
Here is iptables -L output, let me know if you need more info about my config.
Chain INPUT (policy ACCEPT)
target prot opt source destination
GL_SPEC_OPENING all -- anywhere anywhere
ACCEPT all -- anywhere anywhere /* !fw3 */
input_rule all -- anywhere anywhere /* !fw3: Custom input rule chain */
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED /* !fw3 */
syn_flood tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN /* !fw3 */
zone_lan_input all -- anywhere anywhere /* !fw3 */
zone_wan_input all -- anywhere anywhere /* !fw3 */
zone_guestzone_input all -- anywhere anywhere /* !fw3 */
zone_ovpn_input all -- anywhere anywhere /* !fw3 */
Chain FORWARD (policy DROP)
forwarding_rule all -- anywhere anywhere /* !fw3: Custom forwarding rule chain */
zone_lan_forward all -- anywhere anywhere /* !fw3 */
zone_wan_forward all -- anywhere anywhere /* !fw3 */
zone_guestzone_forward all -- anywhere anywhere /* !fw3 */
zone_ovpn_forward all -- anywhere anywhere /* !fw3 */
reject all -- anywhere anywhere /* !fw3 */
Chain OUTPUT (policy ACCEPT)
output_rule all -- anywhere anywhere /* !fw3: Custom output rule chain */
zone_lan_output all -- anywhere anywhere /* !fw3 */
zone_wan_output all -- anywhere anywhere /* !fw3 */
zone_guestzone_output all -- anywhere anywhere /* !fw3 */
zone_ovpn_output all -- anywhere anywhere /* !fw3 */
Chain GL_SPEC_OPENING (1 references)
Chain forwarding_guestzone_rule (1 references)
Chain forwarding_lan_rule (1 references)
Chain forwarding_ovpn_rule (1 references)
Chain forwarding_rule (1 references)
Chain forwarding_wan_rule (1 references)
Chain input_guestzone_rule (1 references)
Chain input_lan_rule (1 references)
Chain input_ovpn_rule (1 references)
Chain input_rule (1 references)
Chain input_wan_rule (1 references)
Chain output_guestzone_rule (1 references)
Chain output_lan_rule (1 references)
Chain output_ovpn_rule (1 references)
Chain output_rule (1 references)
Chain output_wan_rule (1 references)
Chain reject (6 references)
REJECT tcp -- anywhere anywhere /* !fw3 */ reject-with tcp-reset
REJECT all -- anywhere anywhere /* !fw3 */ reject-with icmp-port-unreachable
Chain syn_flood (1 references)
RETURN tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 25/sec burst 50 /* !fw3 */
DROP all -- anywhere anywhere /* !fw3 */
Chain zone_guestzone_dest_ACCEPT (1 references)
Chain zone_guestzone_dest_REJECT (1 references)
Chain zone_guestzone_forward (1 references)
forwarding_guestzone_rule all -- anywhere anywhere /* !fw3: Custom guestzone forwarding rule chain */
zone_ovpn_dest_ACCEPT all -- anywhere anywhere /* !fw3: Zone guestzone to ovpn forwarding policy */
ACCEPT all -- anywhere anywhere ctstate DNAT /* !fw3: Accept port forwards */
zone_guestzone_dest_REJECT all -- anywhere anywhere /* !fw3 */
Chain zone_guestzone_input (1 references)
input_guestzone_rule all -- anywhere anywhere /* !fw3: Custom guestzone input rule chain */
ACCEPT udp -- anywhere anywhere udp dpts:bootps:bootpc /* !fw3: guestzone_DHCP */
ACCEPT tcp -- anywhere anywhere tcp dpt:domain /* !fw3: guestzone_DNS */
ACCEPT udp -- anywhere anywhere udp dpt:domain /* !fw3: guestzone_DNS */
ACCEPT all -- anywhere anywhere ctstate DNAT /* !fw3: Accept port redirections */
zone_guestzone_src_REJECT all -- anywhere anywhere /* !fw3 */
Chain zone_guestzone_output (1 references)
output_guestzone_rule all -- anywhere anywhere /* !fw3: Custom guestzone output rule chain */
zone_guestzone_dest_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_guestzone_src_REJECT (1 references)
Chain zone_lan_dest_ACCEPT (4 references)
Chain zone_lan_forward (1 references)
forwarding_lan_rule all -- anywhere anywhere /* !fw3: Custom lan forwarding rule chain */
zone_ovpn_dest_ACCEPT all -- anywhere anywhere /* !fw3: Zone lan to ovpn forwarding policy */
zone_lan_dest_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_lan_input (1 references)
input_lan_rule all -- anywhere anywhere /* !fw3: Custom lan input rule chain */
zone_lan_src_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_lan_output (1 references)
output_lan_rule all -- anywhere anywhere /* !fw3: Custom lan output rule chain */
Chain zone_lan_src_ACCEPT (1 references)
ACCEPT all -- anywhere anywhere ctstate NEW,UNTRACKED /* !fw3 */
Chain zone_ovpn_dest_ACCEPT (3 references)
DROP all -- anywhere anywhere ctstate INVALID /* !fw3: Prevent NAT leakage */
Chain zone_ovpn_dest_REJECT (1 references)
Chain zone_ovpn_forward (1 references)
forwarding_ovpn_rule all -- anywhere anywhere /* !fw3: Custom ovpn forwarding rule chain */
zone_ovpn_dest_REJECT all -- anywhere anywhere /* !fw3 */
Chain zone_ovpn_input (1 references)
input_ovpn_rule all -- anywhere anywhere /* !fw3: Custom ovpn input rule chain */
zone_ovpn_src_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_ovpn_output (1 references)
output_ovpn_rule all -- anywhere anywhere /* !fw3: Custom ovpn output rule chain */
zone_ovpn_dest_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_ovpn_src_ACCEPT (1 references)
Chain zone_wan_dest_ACCEPT (1 references)
Chain zone_wan_dest_REJECT (1 references)
Chain zone_wan_forward (1 references)
forwarding_wan_rule all -- anywhere anywhere /* !fw3: Custom wan forwarding rule chain */
zone_lan_dest_ACCEPT esp -- anywhere anywhere /* !fw3: Allow-IPSec-ESP */
zone_lan_dest_ACCEPT udp -- anywhere anywhere udp dpt:isakmp /* !fw3: Allow-ISAKMP */
zone_wan_dest_REJECT all -- anywhere anywhere /* !fw3 */
Chain zone_wan_input (1 references)
input_wan_rule all -- anywhere anywhere /* !fw3: Custom wan input rule chain */
ACCEPT udp -- anywhere anywhere udp dpt:bootpc /* !fw3: Allow-DHCP-Renew */
ACCEPT icmp -- anywhere anywhere icmp echo-request /* !fw3: Allow-Ping */
ACCEPT igmp -- anywhere anywhere /* !fw3: Allow-IGMP */
zone_wan_src_REJECT all -- anywhere anywhere /* !fw3 */
Chain zone_wan_output (1 references)
output_wan_rule all -- anywhere anywhere /* !fw3: Custom wan output rule chain */
zone_wan_dest_ACCEPT all -- anywhere anywhere /* !fw3 */
Chain zone_wan_src_REJECT (1 references)
dzwghx
August 6, 2019, 7:45am
3
Can you send a screenshot after the openvpn client connecting?
slava
August 6, 2019, 1:27pm
5
Sure.
I’d also attach OpenVPN logs, but I found nothing in /var/logs
Do you not have the internet for the router itself or for the clients connected to the router?
I have a similar problem here
slava
August 6, 2019, 1:33pm
7
@danger86 Internet works for both clients and router when I disconnect the VPN, when VPN is up internet does not work for both clients and the router.
alzhao
August 6, 2019, 4:44pm
8
Is this your own server?
Problem could happen in the server side or in the local side. From your screenshot there is no data at all.
Does the ovpn works in your PC directly?
slava
August 6, 2019, 7:11pm
9
@alzhao yes, I’m the owner and it works when I connect from my PC directly.
I looked for the gateways: route -n
, and there was no gateway for my OpenVPN server. When I add the GW manually, ping starts working:
ip route add 257.257.257.257/32 via 10.213.90.112 dev wwan0
Where 257.257.257.257
is the IP of my OpenVPN server and 10.213.90.112
is the GW for the wwan0
interface. I’ll try to find a bit more elegant solution, since the GW for wwan0
changes every time I reconnect, but, at least, I found the root of the problem.
slava
August 6, 2019, 8:11pm
10
The problem is that when I connect from my PC, the OpenVPN server gateway is properly pushed to the routing table. I think it’s bug here.
alzhao
August 6, 2019, 8:53pm
11
Can you post your ovpn so that we can check the push options.
slava
August 7, 2019, 12:31pm
12
@alzhao sure.
client
dev tun
proto tcp
remote 257.257.257.257 443
redirect-gateway
resolv-retry infinite
nobind
persist-key
persist-tun
<ca>
-----BEGIN CERTIFICATE-----
1234567abcd
-----END CERTIFICATE-----
</ca>
<cert>
1234567abcd
</cert>
<key>
-----BEGIN PRIVATE KEY-----
1234567abcd
-----END PRIVATE KEY-----
</key>
<tls-crypt>
1234567abcd
</tls-crypt>
auth sha256
cipher AES-256-GCM
auth-nocache
compress lzo
slava
August 7, 2019, 12:33pm
13
I’ll also try to use some 3rd party VPN service/WAN port instead of the 3g/4g modem and let how it works.
slava
August 7, 2019, 12:47pm
14
When I use my VPN server and WAN port to connect to the internet everything works ok! Any ideas?
alzhao
August 7, 2019, 1:11pm
15
Try to change port from 443 to others. Like 1194
Don’t have any idea but seems carrier blocked you. Just do some twisting and try.
Also ssh to the router and get the following when you use 4G and vpn
route
ifstatus wwan
slava
August 10, 2019, 6:30pm
17
alzhao:
route
route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default * 128.0.0.0 U 0 0 0 tun0
default 10.128.142.16 0.0.0.0 UG 0 0 0 tun0
10.128.142.0 10.128.142.16 255.255.255.0 UG 0 0 0 tun0
10.128.142.16 * 255.255.255.255 UH 0 0 0 tun0
10.250.249.116 * 255.255.255.252 U 40 0 0 wwan0
128.0.0.0 * 128.0.0.0 U 0 0 0 tun0
172.16.82.0 10.128.142.16 255.255.255.0 UG 0 0 0 tun0
192.168.94.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.147.0 10.128.142.16 255.255.255.0 UG 0 0 0 tun0
212.53.40.0 10.128.142.16 255.255.255.0 UG 0 0 0 tun0
but occasionally all my VPN-related routes disappear, that’s strange.
slava
August 10, 2019, 6:32pm
18
@alzhao I’m still wondering why it works with the wan port, but does not work with the internal modem.
I see you’re using OpenWrt, maybe I should ask there. Did you modify it to support your devices with multiple WANs/Modems?
alzhao
August 10, 2019, 6:37pm
19
All the things you do should be the same in openwrt and we don’t change it.
One more question, did you use vpn policy in the router?
@robotluo @kyson-lok can you pls have a check of the logs and routes?
slava
August 10, 2019, 6:41pm
20
there is output of route
when I’m using the WAN port.
default 10.248.134.28 0.0.0.0 UG 40 0 0 wwan0
10.248.134.24 * 255.255.255.248 U 40 0 0 wwan0
257.257.257.257 192.168.147.1 255.255.255.255 UGH 0 0 0 eth0
192.168.147.0 * 255.255.255.0 U 10 0 0 eth0
as you can see the GW for my VPN server is configured: 257.257.257.257 via 192.168.147.1
and ifconfig eth0
output
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet addr:192.168.147.123 Bcast:192.168.147.255 Mask:255.255.255.0
inet6 addr: xxxx::xxxx:xxxx:xxxx:xxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:617 errors:0 dropped:24 overruns:0 frame:0
TX packets:285 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:152250 (148.6 KiB) TX bytes:28880 (28.2 KiB)
Interrupt:4
slava
August 10, 2019, 6:44pm
21
Where and how can I configure it?
Also I have strong feeling that eth0
is hardcoded or configured somewhere and that’s why it works.
slava
August 10, 2019, 7:09pm
22
alzhao:
ifconfig wwan0
wwan0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet addr:10.250.249.117 Bcast:10.250.249.119 Mask:255.255.255.252
UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:118 errors:0 dropped:0 overruns:0 frame:0
TX packets:120 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15443 (15.0 KiB) TX bytes:15171 (14.8 KiB)
