No internet with vpn per client
Hello, with global proxy everything is working fine. I want certain devices to not go via VPN. However when I set them to not use the VPN they have no internet connection. Can somebody help me? Block all connections outside vpn is off.
Device: Flint 2
Please let me know the firmware version.
Please check if the VPN enable the killswitch (GLGUI > VPN > VPN Dashboard > VPN client > Global Options > Block Non-VPN Traffic).
If yes, please disable this option.
Thank you for your reaction. I think it had something to do with adguard dns only working on the VPN. When I set another DNS resolver it worked again. Also after updating to beta 4.8.0 I can set a kill switch per client. Great! Thanks for this update.
