No reconnect wireguardclient gl-mt300N-V2
My connection from wireguardclient gl-mt300n-V2 firmware 4.3.10 to the wireguardserver gl-mt300n-V2, firmware 4.3.10 disconnected after 10 minutes and does not reconnect automatically.
Shows “the client is starting, please wait”.
After manualy disable and enable client it connects directly.
logfile client :
Fri Feb 16 10:02:34 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_4428 group_7394 group_361 group_7452 peer_2001 CONFIG_cfg030f15_ports=
Fri Feb 16 10:02:39 2024 user.notice mwan3[18171]: Execute ifup event on interface wgclient (wgclient)
Fri Feb 16 10:02:40 2024 user.notice mwan3[18171]: Starting tracker on interface wgclient (wgclient)
Fri Feb 16 10:02:45 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Fri Feb 16 10:10:26 2024 daemon.notice netifd: Interface 'wgclient' has lost the connection
Fri Feb 16 10:10:27 2024 user.notice mwan3[27469]: Execute ifdown event on interface wgclient (unknown)
Fri Feb 16 10:10:33 2024 daemon.notice netifd: wgclient (27745): [!] Section block_dns (block_dns) is disabled, ignoring section
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Section nat6 option 'reload' is not supported by fw4
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Section gls2s option 'reload' is not supported by fw4
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Section glblock option 'reload' is not supported by fw4
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_guest/01-forward_bypass_domain.nft'
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Automatically including '/usr/share/nftables.d/chain-pre/forward_lan/01-forward_bypass_domain.nft'
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Fri Feb 16 10:10:34 2024 daemon.notice netifd: wgclient (27745): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Fri Feb 16 10:10:34 2024 daemon.notice netifd: Interface 'wgclient' is now down
Fri Feb 16 10:10:34 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Feb 16 10:10:36 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_4428 group_7394 group_361 group_7452 peer_2001 CONFIG_cfg030f15_ports=
Fri Feb 16 10:10:41 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
