I want to build a simple tcp server to create an API for my router. I chose python since that seems to be the language of choice on this router. I want the API so I can send JSON events to update settings and check statuses. I ssh’ed into the router and installed python with the following commands:
opkg update
opkg install python
No if I try to install anything else it says, ‘No space left on device.’ df shows:
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 8064 7928 136 98% /
/dev/root 6912 6912 0 100% /rom
tmpfs 30476 136 30340 0% /tmp
/dev/mtdblock5 8064 7928 136 98% /overlay
overlayfs:/overlay 8064 7928 136 98% /
tmpfs 512 0 512 0% /dev
Is that right? Could it already be full??
