No such file or directory error when trying to conect ProtonVPN
So I have been trying to connect my proton VPN to the router MT-3000 through the website and mobile phone VPN client. I closely followed the instructions downloaded the correct file and placed it in the correct upload space but in the end, when I tried to run it it gave this message on loop:
can't open '/tmp/run/ovpn_resolved_ip': No such file or directory. Additionally, I tried the login page with both my Proton account and the router login but nothing works. What can I do to fix this?
PS. I updated the router software to the newest release.
This message isn't a real error and happens often. You can ignore it.
Maybe tag @bruce and @alzhao they should fix this
May I know have you tried to the WG client as well?
I have tested at my router, both of them work well, could you please share the wg.conf or .ovpn with me via PM and let me check your vpn profile at my side.
I'm also unable to connect to a Torguard VPN on the same MT-3000 router. It started yesterday. I can't connect to Wifi in the repeater option and it also stalls out while starting the VPN client.
If you are unable to connect repeater or vpn pls give full log.
The log you posted does not matter.
But if you cannot connect repeater meanting that you cannot connect to the Internet, surely vpn will not connect.
Sure, sorry not as familiar with networking. I will post the full system log here shortly.
