Since firmwares 4.5.0 and 4.5.16 GL-MT2500 has problems establishing a connection with certain ExpressVPN configuration files, e.g. for the configuration file of the country of Bosnia and Herzegovina. It works with other country configurations such as Croatia.
Please solve the problem and issue a new firmware.
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Apr 14 19:58:55 2024 daemon.err ovpnclient[1849]: RESOLVE: Cannot resolve host address: bosniaandherzegovina-ca-version-2.expressnetw.com:1195 (Name does not resolve)
Sun Apr 14 19:58:55 2024 daemon.warn ovpnclient[1849]: Could not determine IPv4/IPv6 protocol
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: SIGHUP[soft,init_instance] received, process restarting
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: OpenVPN 2.5.3 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Sun Apr 14 19:58:55 2024 daemon.notice ovpnclient[1849]: Restart pause, 5 second(s)
Sun Apr 14 19:59:00 2024 daemon.warn ovpnclient[1849]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sun Apr 14 19:59:00 2024 daemon.warn ovpnclient[1849]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Apr 14 19:59:00 2024 daemon.err ovpnclient[1849]: RESOLVE: Cannot resolve host address: bosniaandherzegovina-ca-version-2.expressnetw.com:1195 (Name does not resolve)
Sun Apr 14 19:59:00 2024 daemon.warn ovpnclient[1849]: Could not determine IPv4/IPv6 protocol
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: SIGHUP[soft,init_instance] received, process restarting
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: OpenVPN 2.5.3 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Sun Apr 14 19:59:00 2024 daemon.notice ovpnclient[1849]: Restart pause, 5 second(s)
