No VPN connection on MT300N with Mullvad and Surfshark
Hi all, I'm having troubles connecting to Mullvad and Surfshark both OpenVPN and WireGuard. I have downloaded configurations from their sites. For Mullvad I used Android setup with 'm' as a password. Please need help.
Log from Mullvad OpenVpn
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: TCP connection established with [AF_INET]146.70.74.98:443
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: TCP_CLIENT link local: (not bound)
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: TCP_CLIENT link remote: [AF_INET]146.70.74.98:443
Sat Aug 3 12:50:52 2024 daemon.err ovpnclient[15655]: Connection reset, restarting [-1]
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: SIGHUP[soft,connection-reset] received, process restarting
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: OpenVPN 2.5.7 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Sat Aug 3 12:50:52 2024 daemon.notice ovpnclient[15655]: Restart pause, 2 second(s)
Sat Aug 3 12:50:54 2024 daemon.warn ovpnclient[15655]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.74.98:443
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: Socket Buffers: R=[131072->360448] S=[16384->360448]
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: Attempting to establish TCP connection with [AF_INET]146.70.74.98:443 [nonblock]
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: TCP connection established with [AF_INET]146.70.74.98:443
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: TCP_CLIENT link local: (not bound)
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: TCP_CLIENT link remote: [AF_INET]146.70.74.98:443
Sat Aug 3 12:50:54 2024 daemon.err ovpnclient[15655]: Connection reset, restarting [-1]
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: SIGHUP[soft,connection-reset] received, process restarting
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: OpenVPN 2.5.7 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Sat Aug 3 12:50:54 2024 daemon.notice ovpnclient[15655]: Restart pause, 2 second(s)
Log from Mullvad WireGuard
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section @forwarding[0] is disabled, ignoring section
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section @forwarding[1] is disabled, ignoring section
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section ovpnclient2wan option 'src' specifies invalid value 'ovpnclient'
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section ovpnclient2wan skipped due to invalid options
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section lan2ovpnclient option 'dest' specifies invalid value 'ovpnclient'
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section lan2ovpnclient skipped due to invalid options
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section guest2ovpnclient option 'dest' specifies invalid value 'ovpnclient'
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section guest2ovpnclient skipped due to invalid options
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section nat6 option 'reload' is not supported by fw4
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section gls2s option 'reload' is not supported by fw4
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Section glblock option 'reload' is not supported by fw4
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Sat Aug 3 12:54:06 2024 daemon.notice netifd: wgclient (20388): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Sat Aug 3 12:54:07 2024 daemon.notice netifd: wgclient (20388): DROP all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 match-set GL_MAC_BLOCK src
Sat Aug 3 12:54:07 2024 daemon.notice netifd: wgclient (20388): Failed to parse json data: unexpected character
Sat Aug 3 12:54:08 2024 daemon.notice netifd: wgclient (20388): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Sat Aug 3 12:54:08 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sat Aug 3 12:54:08 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Thanks!!!
What do you mean by this? Mullvad does not use any passwords, just your login ID.
Clip_2024-08-05_17-29-17
Please ensure your account is right in the Mullvad.
Other hand, please ensure the Mullvad works on your country, use same profile in other OS with WireGuard APP, like the Android WireGuard APP, or Windows/iOS.
Hi, thank you for suggestions, apparently I was using unreachable servers, it works now. Thank you.
