I love this little router, it solves to many problems when traveling… I don’t want my job to know im not in the United States. I have set up my own wireguard server and its working. But when I connected the LAN port, it shows my IP as coming from Mexico, when I disconnect the LAN port and use WIFI, it shows USA. (Beryl router)
I have the following enabled:
Use VPN for all router processes
Internet kill switch
VPN Policies by Mac Address
Don’t use VPN for specific devices
Use VPN for guest network
with all these set, it still doesn’t use VPN for LAN connection…
Hello, I do get different IP Address with WIFI and LAN, they are separate physical adapters in the PC. This is expected. I have confirmed that enabling VPN policies causes the LAN connected devices to ignore the VPN altogether, no matter which device is connected to it. Wireless works as expected, but wired connections don’t work with VPN when VPN policies are enabled.
The MAC addresses for one of my devices is hardcoded (physical hardware, there is no mechanism to generate random MAC) as well but still won’t use VPN .
And of course the MAC address reported in web viewer matches one on LAN adapter, but my policy is “Do not use VPN for xxx” so by default all should use vpn unless in this list, however this only works for WIFI not LAN
Now I see this is really causing an issue because the real IP “leaks” if I accidentally enable VPN policies, also the PC not on VPN can connect to PC on VPN but the connection is not stable enough for remote desktop. Basically WIFI on my device is ustable. on LAN everything is smooth… Is there a way to fix or patch this?
