I have a probleme with my AR300M Router I could not acces the web-interface, wenn I open the 192.168.1.1 I get directely this page 192.168.1.1/cg-bin/luci with OpenWRt on the top oh this page and Authorization request.
I tried the reset bottom but it seems that it is not working (with unplug reset pushed + plug ), no change.
Might be browser cache issue. Try to clear the browser cache and try to accesss the router. If this does not work you may need to clear the settings back to default
I kind of thing what may be the probleme, I Update the fireware with this version openwrt-gl-ar300m-clean-2.264.tar
could thsi the probleme, because now the 192.168.8.1 go directely to http://192.168.8.1/cgi-bin/luci and no Web-interface.
on the bottom there is firmware uplod (NOT setting backup settings)
apload the openwrt-ar300m-nand-2.263.tar
then after reboot all comes normal
thanks again
PS. my problem styl with this late version the OpenVpn is not workin I am VyprVpn client., all is OK with version 2.25 but not with those later firmaware version. any idea there?
