Now how I can build this image myself. There are few packages I would not need (openvpn etc), and would like to have a way to generate this from a image builder, or from the source make. What would be the options?
It looks like your testing mt300a is no longer available. I saw one for ar150 but it doesn’t seem to be working for node either. It seems that no available builds have a working node version.
Do you have an ImageBuilder that has a working node package for the mt300a or ar150?
UPDATE: I found that this file GL.iNet download center has a working version of node. Do you have the ImageBuilder file for this so the build can be customized?
