Nord VPN setup on GL-AXT1800-afo
I am stuck with this message in yellow...
"The client is starting, please wait…"
I am using OpenVPN
please read How to get support quickly and provide the required information.
NordVPN isn't supported out of the box, could you please provide your config file (minus private keys)? Isn't WireGuard the better way to connect?
I am relatively dumb when it comes to settting this up. So I am not sure which way is the best to connect with. Also, where do I find the config file?
Thanks!
If you are relatively dumb, switch to Mullvad or some other provider. Nord isn't good, speaking of setting it up.
If you want to stay with Nord:
