I get Auth-Erros in the log if I try to connect to NordVPN.
My Slate 7 uses firmware 4.7.3.
I added the service credentials from the NordVPN site and downloaded some configurations.
Switching on the VPN service shows the Auth-Erros in the log.
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TCP connection established with [AF_INET]5.180.62.96:443
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TCPv4_CLIENT link local: (not bound)
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TCPv4_CLIENT link remote: [AF_INET]5.180.62.96:443
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TLS: Initial packet from [AF_INET]5.180.62.96:443, sid=d9a1bfea e7dd7861
Tue Jun 17 07:30:52 2025 daemon.warn ovpnclient[28291]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA10
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY KU OK
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: Validating certificate extended key usage
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY EKU OK
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY X509NAME OK: CN=de984.nordvpn.com
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: VERIFY OK: depth=0, CN=de984.nordvpn.com
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bits RSA, signature: RSA-SHA512, peer temporary key: 253 bits X25519
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: [de984.nordvpn.com] Peer Connection Initiated with [AF_INET]5.180.62.96:443
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Tue Jun 17 07:30:52 2025 daemon.notice ovpnclient[28291]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Tue Jun 17 07:30:53 2025 daemon.notice ovpnclient[28291]: SENT CONTROL [de984.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Tue Jun 17 07:30:53 2025 daemon.notice ovpnclient[28291]: AUTH: Received control message: AUTH_FAILED
Tue Jun 17 07:30:53 2025 daemon.notice ovpnclient[28291]: SIGTERM[soft,auth-failure] received, process exiting
Any ideas what's wrong?
Yours, Tolotos
Yes I'm able to connect via mobile phone and pc to the VPN
Yes I used this service credentials. But I copied it same days ago. Since yesterday I can't access the credentials as the Email sending the verification numbers is not arriving - I created a ticket for this. So the credentials may be outdated?!
I tried with a TCP profile (de984.nordvpn.com.tcp)
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TCP connection established with [AF_INET]5.180.62.96:443
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TCPv4_CLIENT link local: (not bound)
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TCPv4_CLIENT link remote: [AF_INET]5.180.62.96:443
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TLS: Initial packet from [AF_INET]5.180.62.96:443, sid=a4529c36 080eb63e
Tue Jun 17 10:55:15 2025 daemon.warn ovpnclient[15982]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA10
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY KU OK
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: Validating certificate extended key usage
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY EKU OK
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY X509NAME OK: CN=de984.nordvpn.com
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: VERIFY OK: depth=0, CN=de984.nordvpn.com
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bits RSA, signature: RSA-SHA512, peer temporary key: 253 bits X25519
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: [de984.nordvpn.com] Peer Connection Initiated with [AF_INET]5.180.62.96:443
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Tue Jun 17 10:55:15 2025 daemon.notice ovpnclient[15982]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Tue Jun 17 10:55:16 2025 daemon.notice ovpnclient[15982]: SENT CONTROL [de984.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Tue Jun 17 10:55:16 2025 daemon.notice ovpnclient[15982]: AUTH: Received control message: AUTH_FAILED
Tue Jun 17 10:55:16 2025 daemon.notice ovpnclient[15982]: SIGTERM[soft,auth-failure] received, process exiting
NordVPN solved the issue with sending me the verification email. And
the credetials are changed. With the new one I can create a connection. Hopefully they don't change it again during my holidays.
