NordVPN Wireguard Brume2
Hi. So now I’ve got NordVPN I’ve added it to Brume 2. I assume the fact the Nord logo is showing under vpn client, Glinet now supports NordLynx natively? My other query is servers. When I get the access token and look at vpn client country options, why does it only show Seattle? It shows 20 servers in Seattle but no other location in America. However when I load the iOS or Apple TV Nord app, I can choose a huge number of locations throughout the whole of America. What’s going on?
Thanks !!!!
The 20 server limit is currently an issue on Nords side:
Thanks but it still doesn’t make sense as it shows 20 servers in US that are all in Seattle. Weird. Why Seattle …
I’ve just emailed Nord Support about this API flaw. Interesting to see what they say. I’ve also sent them a screenshot from gl.iNet nord selection screen. Expect they will say they’ve never heard of it and it’s a Gl.Inet issue. LOL.
Nord have just come back to me saying it’s basically a fault with Gl.INet, not them:
“” Unfortunately, as the Pre-built NordVPN configuration was made by Gl.Inet themselves, there's not much we can do to assist. It's outside our scope of support.””
I did reference the API but they’ve said it’s a Gl.INet issue?
Bruce can you advise? Thanks!
Follow up by Nord:
“” The NordVPN pre-built configuration was made by the Gl.Inet team, there was no involvement from our side.””
Surely Gl.INet need to get on top of this 20 server Nord limit. Seems clear it’s a Gl.iNet problem now.
Best would be to withdraw the NordVPN integration until it's stable then.
Can we get an official comment on this? Thanks
What else official do you need? :wink:
Just wanted some clarification really as Nord were telling me they had no involvement in the Gl.INet integration. And they’ve basically said to me the integration was a bit of a hack as it’s not supported by them. So I was interested to know where this 20 server limit comes from when Nord had no involvement?
Pretty sure because GL reverse engineered the Nord API somehow, I guess. More for convenient usage of the router than for being in partnership with Nord.
@bruce Maybe you can do an more or less official statement here?
We never reverse engineered the Nord or related anything.
We have cooperation with Nord, and they provide the APIs, otherwise how can Nord allow APIs to obtain such important information such as VPN profiles, and also can login to the NordVPN credentials in GL GUI.
I will ask with R&D about this issue.
So weird that Nord says there is no cooperation then .... Damn, I hate them so much :smile:
I hope this can be fixed, I’d like to use WireGuard too.
Nord people are just lazy because they should allow you to download WG config files manually like Proton, Mullvad, etc.
I have communicated with relevant guys.
This is because Nord VPN has restrictions about the external APIs.
The US indeed only display the group of Seattle.
We will try to further negotiate and communicate with NordVPN.
I'd like to know if there was any update to this issue. It would be great to find some sort of solution to this problem!
Also as a side note, are the APIs being used by GLiNet documented anywhere and available to the public (at least using our own credentials)? If yes, I could look at creating a script to help remedy the problem with a temporary solution while both companies can figure something out to make the user experience smoother!
Since I accidentally deleted my older post, here's the content:
Really appreciate the work being done with enabling WireGuard for NordVPN!
Just want to point out that the issue is not only with the US, it is for other countries too, Canada only shows Vancouver etc.
The only request or suggestion I have is, if Nord won't budge on the 20 response item limit, then I think it would be better to have multiple cities with lesser servers. Ex: Instead of 20 Seattle/Vancouver servers, 5 servers in 4 different cities in each country. This would give the benefit of low latency + redundancy for servers. I don't know if this is possible with the current APIs or not, but just a suggestion to consider.
Thank you again, and hope to see this resolved soon!
I'm on Beryl AX on the latest firmware btw
What about using another VPN provider?
I prefer to create and use my own config files - from my own hosted server. Obviously not everyone is going to go to the same effort. Surely there is a middle ground - where you can at least choose an exit point that suits your needs.
Is there an update on this matter so far? If you cooperate with NordVPN, then it shouldn't be taking long, right?
What I would like to see is the ability to select a country, then select a region. If the API allows only 20 servers, then I could as well just select 4 or 5 servers in total per region.
I have never had the need to use multiple Wireguard servers concurrently.
From where I sit, I just need to use "the nearest (NY)", less loaded servers. Seattle is too far from me.
Please check it again. We have updated the API.
More US servers are available for selection. The same applies to other regions.
This is AWESOME!
Thank you for fixing the API.
