Help I got the new flint 2 router. I tried to connect the wifi( password provided back side of the router) when I tried it’s not connecting ( incorrect password). Then I tied to connecting with QR code ( provided back side of the router) still not working this time I am getting error like unable to connect. Final option I tried to reset the modem. And tried again but still same issue. Could you please help me to fix this issue or it’s common issue in Flint 2.
That is strange.
But if you use a cable you must be able to login via the web ui at 192.168.8.1
, from there you can also change wifi or verify back with the label.
In case the label mismatch would be a good idea to report it here👍
You have to log in to the router first via lan connection, only then you will have access to wifi.
Its in the instructions provided with the router.
Thanks lan was working. I am able to set the password looks like they have pasted wrong sticker on modam
You were most likely sent a used and returned unit where the default password was already changed.
