Not finding network
Hello
I just got the Beryl AX
In my building, there is a free net with captive portal. So lots of things can't connect to it. So I bought the Beryl.
It seems now that the net is turning off daily for 10 minutes.
So Beryl disconnects
When the net is back, it doesn't reconnect and the repeater function turns off.
When I try to turn it ON, it doesn't find any network at all.
So I had reset Beryl and restart over.
Any ideas what should I do?
At least, how to reconnect without doing a hard reset again and again.
Thank you
Hi Neraad,
try the op24 Version. This one is working for me.
https://dl.gl-inet.com/release/router/rc/mt3000-open/4.6.4-op24
Important: Start from scratch, don't keep settings.
Buntspext
Upgrade to the latest firmware version always.
Does the free wifi has different BSSIDs that use different channel?
The Beryl should not be reset to find new network. Seems there are some bugs.
Pls report after you upgrade the latest firmware or use op24 firmware and get the log when the problem happens.
Thank you very much for your help.
I installed it yesterday from scratch and seems to be stable.
Hopefully it will remain like this.
I installed the op24 yesterday.
I will update you just in case.
Thank you very much once again
This seems to solve the issue I had
