bonjour la page d acceuil de mon routeur est differente de la photo amazon la page a t elle changer? je n arrive pas a insttaller le vpn winsdcribe dans openvpn
modele mt300n pouvez vous m aide merci
Are you ensure that you buy from our channel?
If it is our stock firmware, you can refer to this link: OpenVPN Client - GL.iNet Docs
Please make an effort and speak English if you want help!
Presumably the welcome page has changed because Amazon shows firmware V2 and you have firmware V3.
To install VPN, please refer to the support docs:
It is our stock firmware. You can refer to this link to set OpenVPN up. VPN - GL.iNet Docs
ok merci pour les reponses
Okay, thanks for the answers
