I am a CA State employee that is currently teleworking from home. I am looking at some real estate opportunities in Cabo San Lucas Mexico and would like to take my equipment and work there for a few months.
Is it possible to configure the MV1000W to operate via WiFi and use my NordVPN account to mask my location and allow me to work without detection?
If so how can I set it up because not able to put GL or NordVPN on my work desktop. Any recommendations?
Alzhao,
Thanks for the response. I was on the right track and I am taking your advice and using the mobile app to manage the client using a server in Cali… I identified and saved a couple to the mobile app already!
Thanks again…I am traveling to Cabo on Saturday…I will message you if I run into any issues, if you don’t mind!
I got to Cabo and was unable to connect to the MV1000. I think the main issue was that the unit was set up on my home wifi. It worked fine at home as I was able to access/use my work desktop wirelessly.
I think the big issue is that when I initially set it up, I set it up in Repeater mode that had me assign my home network as the SSID. I was unable to access the MV1000 or make changes to because I needed to connect to it through my home network 1st? Does that make sense?
I tried to use a LAN connection to change it but was unable to reboot or reset it. Couldn’t access the http://192.168.8.1/
Tried all the different browsers.
The updated application (white logo)wouldn’t load and was unable to access admin page on the(green logo) application.
I am sure it will work. Just need to resolve the application access issues to make the changes.
Any suggestions
Another issue was I was not able to access the application page in order to change the wifi settings
I was unable to reset the unit to factory settings
