Hey! When starting a scan for APs when enabling repeater, or when going to Luci and doing a channel analysis, the entire router sometimes crashes (and if not, just returns no values in the case of repeater)
I have tried factory resetting it, and it still breaks. Note, in all cases, wifi modes are set to 5ghz 11n/ac/ax with channel fixed at 161, and 2.4ghz 11n/ax with channel set to 11. The crash log mentioned I was also doing tethering from a phone, but this seems to be an issue regardless of tethering or not, and does not have an effect over whether it crashes vs just fails.
I am connected over wifi while this happens, so the expectation is to see a disconnect + reconnect here.
Note the crash does not always happen - when it doesn’t crash, channel analysis works fine, but the repeater AP scan still shows no entries.
Model: GL.iNet GL-MT6000
Firmware version: 4.5.5
Firmware type: release3
OpenWRT version: OpenWrt 23.05-SNAPSHOT r23001+719-38c150612c
Kernel version: 5.15.139
Oops#1 Part1
<6>[ 15.142016] br-lan: port 5(lan5) entered blocking state
<6>[ 15.147236] br-lan: port 5(lan5) entered disabled state
<6>[ 15.154604] device lan5 entered promiscuous mode
<6>[ 15.487770] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY] (irq=62)
<6>[ 15.498023] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/2500base-x link mode
<6>[ 16.216717] br-lan: port 6(wlan0) entered blocking state
<6>[ 16.222112] br-lan: port 6(wlan0) entered disabled state
<6>[ 16.227668] device wlan0 entered promiscuous mode
<6>[ 16.288563] device wlan0 left promiscuous mode
<6>[ 16.293098] br-lan: port 6(wlan0) entered disabled state
<6>[ 16.373345] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[ 16.419841] br-lan: port 1(lan1) entered blocking state
<6>[ 16.425081] br-lan: port 1(lan1) entered forwarding state
<6>[ 16.472664] br-lan: port 6(wlan0) entered blocking state
<6>[ 16.478000] br-lan: port 6(wlan0) entered disabled state
<6>[ 16.483531] device wlan0 entered promiscuous mode
<6>[ 16.488461] br-lan: port 6(wlan0) entered blocking state
<6>[ 16.493795] br-lan: port 6(wlan0) entered forwarding state
<6>[ 16.653594] br-lan: port 6(wlan0) entered disabled state
<6>[ 16.716596] tertf: br-lan registered, add it
<6>[ 16.723354] br-lan: port 7(wlan1) entered blocking state
<6>[ 16.728734] br-lan: port 7(wlan1) entered disabled state
<6>[ 16.734289] device wlan1 entered promiscuous mode
<6>[ 16.788442] device wlan1 left promiscuous mode
<6>[ 16.793015] br-lan: port 7(wlan1) entered disabled state
<6>[ 16.977290] br-lan: port 7(wlan1) entered blocking state
<6>[ 16.982645] br-lan: port 7(wlan1) entered disabled state
<6>[ 16.988174] device wlan1 entered promiscuous mode
<6>[ 16.993031] br-lan: port 7(wlan1) entered blocking state
<6>[ 16.998362] br-lan: port 7(wlan1) entered forwarding state
<6>[ 17.700346] br-lan: port 7(wlan1) entered disabled state
<6>[ 17.944422] br-lan: port 7(wlan1) entered blocking state
<6>[ 17.949776] br-lan: port 7(wlan1) entered forwarding state
<6>[ 18.087726] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[ 18.095732] br-lan: port 3(lan3) entered blocking state
<6>[ 18.100983] br-lan: port 3(lan3) entered forwarding state
<6>[ 18.230083] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[ 18.238057] br-lan: port 4(lan4) entered blocking state
<6>[ 18.243289] br-lan: port 4(lan4) entered forwarding state
<7>[ 19.379608] xt_FULLCONENAT: warning: failed to register a conntrack notifier. Disable active GC for mappings.
<6>[ 27.301800] br-lan: port 6(wlan0) entered blocking state
<6>[ 27.307117] br-lan: port 6(wlan0) entered forwarding state
<6>[ 44.775013] usb 1-2: USB disconnect, device number 2
<6>[ 45.427763] usb 1-2: new high-speed USB device number 3 using xhci-mtk
<6>[ 45.615614] rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-11200000.usb-2, RNDIS device, 06:8d:71:ac:e7:ac
<7>[ 46.764582] [add_dev_config 307]add node success. iface:tethering, dev:usb0, ifindex:14
<1>[ 203.168669] Unable to handle kernel write to read-only memory at virtual address 0000000000000000
<1>[ 203.177550] Mem abort info:
<1>[ 203.180336] ESR = 0x0000000096000045
<1>[ 203.184081] EC = 0x25: DABT (current EL), IL = 32 bits
<1>[ 203.189379] SET = 0, FnV = 0
<1>[ 203.192422] EA = 0, S1PTW = 0
<1>[ 203.195548] FSC = 0x05: level 1 translation fault
<1>[ 203.200406] Data abort info:
<1>[ 203.203274] ISV = 0, ISS = 0x00000045
<1>[ 203.207092] CM = 0, WnR = 1
<1>[ 203.210043] user pgtable: 4k pages, 39-bit VAs, pgdp=000000004a619000
<1>[ 203.216467] [0000000000000000] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
<0>[ 203.225149] Internal error: Oops: 0000000096000045 [#1] SMP
<7>[ 203.230703] Modules linked in: xt_FULLCONENAT pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_ipv6 nf_flow_table_ipv4 nf_flow_table_inet mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_helper xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_CT usbserial usbnet slhc poly1305_neon nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_objref nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_counter nft_compat nft_chain_nat nf_tables nf_reject_ipv4 nf_log_syslog nf_flow_table nf_conntrack_netlink nf_conncount mdio_netlink libcurve25519_generic libcrc32c libchacha iptable_nat
<7>[ 203.230842] iptable_mangle iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic seqiv md5 des_generic libdes authencesn authenc mtdoops uas usb_storage leds_gpio xhci_plat_hcd xhci_pci
<7>[ 203.318165] xhci_mtk_hcd xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list vfat fat exfat usbcore usb_common mii gl_sdk4_hw_info
<7>[ 203.425752] CPU: 1 PID: 387 Comm: napi/mtk_eth-6 Not tainted 5.15.139 #0
<7>[ 203.432433] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[ 203.437118] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[ 203.444058] pc : mt76_tx+0xb8/0x630 [mt76]
<7>[ 203.448152] lr : mt7915_eeprom_get_power_delta+0x1928/0x2580 [mt7915e]
<7>[ 203.454665] sp : ffffffc0099d3400
<7>[ 203.457963] x29: ffffffc0099d3400 x28: ffffff8005b69928 x27: ffffff8004d88d90
<7>[ 203.465079] x26: ffffffc0099d35b0 x25: ffffff800a7c1958 x24: 0000000000000000
<7>[ 203.472194] x23: ffffff8005b69928 x22: ffffffc000fdffa8 x21: ffffff8005b69900
<7>[ 203.479310] x20: ffffff8004d8a020 x19: ffffff8005926cc8 x18: 0000000000000000
<7>[ 203.486426] x17: 0000000000000a40 x16: ffffffc008f2b000 x15: 0000000000000520
<7>[ 203.493542] x14: ffffffffffffd9f8 x13: 00000003aaaa0000 x12: 0000000000000000
<7>[ 203.500657] x11: ffffff8001e1d560 x10: ffffff8001de9150 x9 : ffffff8001e1d540
<7>[ 203.507772] x8 : 0000000042f6eb50 x7 : ffffff800c498100 x6 : 00000000f0000010
<7>[ 203.514888] x5 : ffffff8004ee2020 x4 : 0000000000000000 x3 : 0000000000000001
<7>[ 203.522002] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff8005926e00
<7>[ 203.529119] Call trace:
<7>[ 203.531551] mt76_tx+0xb8/0x630 [mt76]
<7>[ 203.535287] mt7915_eeprom_get_power_delta+0x1928/0x2580 [mt7915e]
<7>[ 203.541451] __ieee80211_schedule_txq+0xe60/0x1b30 [mac80211]
<7>[ 203.547206] __ieee80211_xmit_fast+0x7b4/0x950 [mac80211]
<7>[ 203.552600] __ieee80211_subif_start_xmit+0x1e8/0x354 [mac80211]
<7>[ 203.558603] ieee80211_subif_start_xmit+0x3c/0x3bc [mac80211]
<7>[ 203.564345] ieee80211_subif_start_xmit_8023+0x318/0x430 [mac80211]
<7>[ 203.570606] dev_hard_start_xmit+0xe4/0x180
<7>[ 203.574776] __dev_queue_xmit+0x968/0xc30
<7>[ 203.578769] dev_queue_xmit+0x10/0x20
<7>[ 203.582415] br_dev_queue_push_xmit+0x9c/0x1b4
<7>[ 203.586845] br_forward_finish+0x98/0xb0
<7>[ 203.590752] __br_forward+0x138/0x1a0
<7>[ 203.594399] br_forward+0x124/0x150
<7>[ 203.597873] br_handle_frame_finish+0x30c/0x4d0
<7>[ 203.602386] br_handle_frame+0x398/0x41c
<7>[ 203.606291] __netif_receive_skb_core.constprop.0+0x254/0xcb0
<7>[ 203.612018] __netif_receive_skb_list_core+0xd4/0x1e0
<7>[ 203.617050] netif_receive_skb_list_internal+0x1b8/0x280
<7>[ 203.622343] napi_complete_done+0x64/0x1a0
<7>[ 203.626423] gro_cell_poll+0x80/0xa0
<7>[ 203.629986] __napi_poll+0x54/0x1b0
<7>[ 203.633460] net_rx_action+0x2a0/0x320
<7>[ 203.637192] _stext+0x10c/0x28c
<7>[ 203.640320] do_softirq+0x8c/0xa0
<7>[ 203.643623] __local_bh_enable_ip+0xa0/0xa4
<7>[ 203.647789] napi_threaded_poll+0x120/0x1a0
<7>[ 203.651956] kthread+0x11c/0x130
<7>[ 203.655173] ret_from_fork+0x10/0x20
<0>[ 203.658735] Code: f90002a0 52800002 f90006a1 f900a275 (f9000035)
<4>[ 203.664808] ---[ end trace eb5248042cf7d915 ]---
Panic#2 Part1
<0>[ 203.673566] Kernel panic - not syncing: Oops: Fatal exception in interrupt
<2>[ 203.680420] SMP: stopping secondary CPUs
<0>[ 203.684326] Kernel Offset: disabled
<0>[ 203.687796] CPU features: 0x0,00000000,20000802
<0>[ 203.692309] Memory Limit: none
Possibly also relevant: system log when doing a repeater scan when the system does not crash:
Sun Jan 21 02:59:58 2024 daemon.info gl-repeater[10535]: (repeater.lua:208) scanning...
Sun Jan 21 02:59:59 2024 daemon.err gl-repeater[10535]: (gl-repeater.lua:239) /usr/local/lib/lua/5.3/eco/nl80211.lua:439: attempt to perform bitwise operation on a nil value
Sun Jan 21 03:00:01 2024 daemon.info gl-repeater[11875]: (gl-repeater.lua:253) lua-eco version: 3.2.0
Sun Jan 21 03:00:01 2024 daemon.info gl-repeater[11875]: (gl-repeater.lua: 16) load repeater config...
Sun Jan 21 03:00:01 2024 daemon.info gl-repeater[11875]: (gl-repeater.lua:222) wait ap ready...
Sun Jan 21 03:00:01 2024 daemon.info gl-repeater[11875]: (gl-repeater.lua: 82) load wifi config...
Sun Jan 21 03:00:02 2024 daemon.info gl-repeater[11875]: (repeater.lua:690) switch in 0 seconds...
Sun Jan 21 03:00:02 2024 daemon.info gl-repeater[11875]: (repeater.lua:634) disabled
