- GL-AX1800 (Flint)
- firmware version 4.6.2 type release2
- via cable to my ISP
- dns server next dns
- DHCP
Here some logs
Sun Aug 25 03:34:59 2024 kern.warn kernel: [ 4780.620222] [add_dev_config 287]add node success. iface:wan, dev:eth0, ifindex:2
Sun Aug 25 03:35:00 2024 daemon.info avahi-daemon[5095]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe16:fef0.
Sun Aug 25 03:35:00 2024 daemon.info avahi-daemon[5095]: New relevant interface eth0.IPv6 for mDNS.
Sun Aug 25 03:35:00 2024 daemon.info avahi-daemon[5095]: Registering new address record for fe80::9683:c4ff:fe16:fef0 on eth0.*.
Sun Aug 25 03:40:07 2024 daemon.notice netifd: Network device 'eth0' link is down
Sun Aug 25 03:40:07 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sun Aug 25 03:40:07 2024 kern.info kernel: [ 5088.445715] nss-dp 3a001000.dp1 eth0: PHY Link is down
Sun Aug 25 03:40:07 2024 daemon.notice netifd: wan (17323): udhcpc: received SIGTERM
Sun Aug 25 03:40:07 2024 daemon.notice netifd: wan (17323): udhcpc: unicasting a release of 10.35.220.45 to 10.37.126.50
Sun Aug 25 03:40:07 2024 daemon.notice netifd: wan (17323): udhcpc: sending release
Sun Aug 25 03:40:07 2024 daemon.notice netifd: wan (17323): udhcpc: entering released state
Sun Aug 25 03:40:07 2024 daemon.notice netifd: wan (17323): Command failed: Permission denied
Sun Aug 25 03:40:07 2024 daemon.notice netifd: Interface 'wan' is now down
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Withdrawing address record for 10.35.220.45 on eth0.
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Leaving mDNS multicast group on interface eth0.IPv4 with address 10.35.220.45.
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Interface eth0.IPv4 no longer relevant for mDNS.
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Interface eth0.IPv6 no longer relevant for mDNS.
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe16:fef0.
Sun Aug 25 03:40:07 2024 daemon.info avahi-daemon[5095]: Withdrawing address record for fe80::9683:c4ff:fe16:fef0 on eth0.
Sun Aug 25 03:40:07 2024 daemon.notice netifd: Interface 'wan' is disabled
Sun Aug 25 03:40:07 2024 daemon.notice netifd: Interface 'wan' is enabled
Sun Aug 25 03:40:07 2024 kern.info kernel: [ 5088.507665] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sun Aug 25 03:40:07 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Sun Aug 25 03:40:08 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Sun Aug 25 03:40:08 2024 kern.warn kernel: [ 5089.321079] kmwan: Delete node:wan
Sun Aug 25 03:40:08 2024 daemon.err stubby[16171]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Sun Aug 25 03:40:10 2024 daemon.err stubby[16171]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Sun Aug 25 03:40:13 2024 daemon.err stubby[16171]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Sun Aug 25 03:40:15 2024 daemon.err stubby[16171]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Sun Aug 25 03:40:16 2024 daemon.notice netifd: Network device 'eth0' link is up
Sun Aug 25 03:40:16 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Sun Aug 25 03:40:16 2024 daemon.notice netifd: Interface 'wan' is setting up now
Sun Aug 25 03:40:16 2024 kern.info kernel: [ 5097.445427] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 100
Sun Aug 25 03:40:16 2024 kern.info kernel: [ 5097.445491] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sun Aug 25 03:40:16 2024 daemon.notice netifd: wan (19846): udhcpc: started, v1.33.2
Sun Aug 25 03:40:16 2024 daemon.notice netifd: wan (19846): udhcpc: sending discover
Sun Aug 25 03:40:16 2024 daemon.notice netifd: wan (19846): udhcpc: sending select for 10.35.220.45
Sun Aug 25 03:40:16 2024 daemon.notice netifd: wan (19846): udhcpc: lease of 10.35.220.45 obtained, lease time 86400
Sun Aug 25 03:40:16 2024 daemon.info avahi-daemon[5095]: Joining mDNS multicast group on interface eth0.IPv4 with address 10.35.220.45.
Sun Aug 25 03:40:16 2024 daemon.info avahi-daemon[5095]: New relevant interface eth0.IPv4 for mDNS.
Sun Aug 25 03:40:16 2024 daemon.info avahi-daemon[5095]: Registering new address record for 10.35.220.45 on eth0.IPv4.
Sun Aug 25 03:40:16 2024 daemon.notice netifd: Interface 'wan' is now up
Sun Aug 25 03:40:16 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Sun Aug 25 03:40:17 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
