Omegle.com doesn’t work when using GL-X300B-GPS when trying to access it. With same sim, and ZTE modem it works great, and without problems.
Please advise, as i think there is some setting in router. Please note that i enabled DMZ already, but it doesn’t work? Do i need a restart to make DMZ come into affect?
Yes, it gives 5 addresses back. Note that i checked what is happening with Wireshark, and it is listening on 443 port. I opened it up, didn’t work, then i let everything open for this one device? It is weird, as it opens up the page but cams of people are not loading.
Umm… so page openes like normal, everything is normal just cams wont open? As i said, if i connect this card back to ZTE it works like it should? Where do i set DNS encryption and why do you think that is the problem here?
Routers may have different DNS Settings if the carrier offers the same service, so I’ll let you try DNS encryption.
In addition, what is the current modem model for the X300B? Carriers may have restrictions on different device types.
You can also try specifying a TTL of 65 in manual Settings
I see what is wrong now. Router assigns different PORT to my computer with every connection. How can i make port not shuffle with every new connection to user? Can this be fixed? So my computer, fixed IP, and fixed opened port?
In a router, the source port address is always random, but this should not affect network access. I think the TTL or MTU parameters most likely affect it.
One interesting thing I noticed was that when I was parsing the omegle domain name properly, the DNS server returned me an IP of 104.23.142.25.
I can access this address normally, even on the X300B.
But when I tried domain resolution with the X300B, I got the wrong address
After I configure DNS encryption, the domain name is resolved correctly
I want to confirm that you have tried DNS encryption and confirmed that it does not solve the problem?
It doesn’t work for me either whilst behind a VPN which also protects the DNS info. I’ve checked for DNS leaks and it always give the VPN info as its supposed to but Omegle says “Error connecting to server. Please try again”. I suspect they block my VPN IP due to previous misuse of their service by others under the same IP. I use a MangoV2 with binding protection enabled but I would never enable protection provided by Cloudflare. If they see you visit KiwiFarms they will dispatch a SWAT team to your grandma’s house.
