Broken (the formatting is broken and lots of previously available details such as dependencies are missing):
Here's how to fix it since the router has moved to apk:
apk query --fields name,version,description,file-size,depends ddns-scripts-cloudflare
# or if you want it as JSON for even nicer UI formatting:
apk query --format json --fields name,version,description,file-size,depends ddns-scripts-cloudflare
Results:
root@GL-MT6000:~# apk query --fields name,version,description,file-size,depends
Version: 2.8.4-r1
Description: Dynamic DNS Client scripts extension for cloudflare.com API v4 (require curl)
File-Size: 4617
Depends: curl ddns-scripts libc
root@GL-MT6000:~# apk query --format json --fields name,version,description,file
"name": "ddns-scripts-cloudflare",
"version": "2.8.4-r1",
"description": "Dynamic DNS Client scripts extension for cloudflare.com API v4 (require curl)",
"file-size": 4617,
"depends": [
"curl",
"ddns-scripts",
"libc"
