I updated firmware. Then factory reset. Now I cannot log on to Opal using wifi password on the bottom of the router. Or goodlife.
I read on this forum that perhaps there is a bug in the new firmware that means the WiFi password is reset to a random number after this combo and that the only way to retrieve is to use an ethernet cable.
Is this really true? It seems like a bit of a majjor failing. I have no computers with ethernet ports and if it is, then I have no choice other to return it as not working.
