I continue to struggle on some of the various network modes.
I am trying to remotely connect a wired device to my home network using Opal.
So my remote device gets wired to Opal and Opal connects to my home Wifi.
I want the remote device to be discoverable on my home network.
It sounds like I should choose Repeater mode, but I know that puts a firewall between the remote device and my home network, and the app I use to connect to the remote device does not recognize it.
I had some success with Extender, but it doesn’t seem to always work.
I do not need Opal to re-broadcast anything - I just need Opal to connect to my home Wifi and provide a wired connection to my device. I then need a network appliance on my home network to be able to recognize that the remote device is on the home network.
This seems quite straightforward, but I can’t quite seem to get it to work reliably.
It is possible that my issue is that I am using Opal to repeat a WiFi being broadcast by an access point that is hard-wired to my home network. So my remote device is hard-wired to an Opal LAN port; Opal is configured as a repeater connected to the AP WiFi. And the AP is hard-wired to my home network router.
