I’m experiencing a somewhat odd issue with my Opal router that never happened before. Here’s the situation:
A few months ago, I connected my Opal to my home router in router mode (5GHz Opal → 5GHz home router). Speeds were about half of my main connection, which is normal for this setup.
However, after returning from a road trip and reconnecting the Opal to my home router, I started noticing that whenever I download or stream at high rates, the connection would briefly drop. Specifically:
Downloads or streams would pause or stop.
Checking the Opal dashboard, the repeater shows “connecting…” with a yellow icon, even though it remains connected overall.
This only happens during heavy downloads / speed tests.
What’s strange is that this never happened before. I’ve tested the same setup on a few other routers (friends’ networks) and had no disconnects.
What I’ve tried so far:
Set a manual IP for the Opal on my router.
Tried connecting the Opal to my router’s 2.4GHz network (same issue).
Restarted both devices.
Verified the Opal firmware is fully up to date.
I haven’t changed any settings on either router.
Before I do a full factory reset of the Opal, I wanted to see if anyone here has experienced this behavior or has suggestions on how to fix it. Could this be a firmware glitch, a compatibility issue, or something else?
Just a gentle reminder.
Could you please confirm that you are using the original power supply or another power source that meets the required 5V/3A specifications?
I went ahead and reset the firmware to see if something under the hood (settings, etc.) might have been causing the issue, but the problem still persists on firmware version 4.3.25. If it helps, I’m happy to share my logs of the event.
For now, I upgraded to the Beta 4.7.2, which seems to be working about 99% of the time. I’m wondering if something may have happened with the most recent stable firmware that I wasn’t aware of?
If the Beta starts to show problems, I’ll try rolling back through the stable versions to see where the issue first appears.
Yes, if the issue occurs again, please export the logs so we can further examine and analyze.
Additionally, please note the LED status of the device when the problem occurs to check if a reboot has taken place.
