I have an Opal router configured as a Wireguard client, and the connection is fine. My issue is that the Ethernet interface has lost connection twice in two days. When it does, the Opal gets a DHCP address from the primary router, and all traffic then goes through the primary router.
The Opal is running the latest firmware. Block all non-VPN traffic is enabled. Rebooted both routers, and the issue still persists.
Is there any way to disable this failover when the Opal Ethernet interface cannot connect, and then traffic is routed to the primary router?
Thanks in advance.
