Open WRT 24.10 for Marble (GL-B3000)
is OpenWRT 24.10 avail. for Marble (GL-B3000) ?
What Image can i use for that Router ?
Is there an Instruction or Video for ?
Regards
Rainer
You can find all available firmware images here: GL.iNet download center
Please keep in mind that there might be official OpenWrt images, but they are not supported by GL.
It's almost available direct from Openwrt, just a few more adjustments needed.
Works fine but you lose all of the GL goodies
Hi, I searched in OPENWRT hardware page, but I didn't find the B3000, is it normal ?, flash is possible with teh GUI ?
Flash is possible with the gui.
PR request is here:
It's being finalised at present.
Hello KWRT (TheRootED24).
In your images, there is no wireless included at luci Interface
Is there a way to install it ?
Regards Rainer
Thank you, last question, is there Luci in the image ? I can set up the wireless with the new GUI ?
Yes Luci was in the KWRT Image, but not wireless. So the Router could only be used as a LAN Device.
I used the KWRT Files from openwrt.ai that had no Wireless. Seems i used the wrong files. In your repository there is wireless
Sorry for my confusion
Hi, I installed RC3 for B3000, everything work, but I have slow speed, I cheked, wifi speed seem ok in the GUI, but the internet speed slow down from 600 mega to 150 mega n speedtest.
maybe related to this one ?
B3000 PR has finally been merged into Vanilla Openwrt.
It's live:
https://downloads.openwrt.org/snapshots/targets/qualcommax/ipq50xx/
This afternoon, I downloaded the factory.img snapshot and installed it on my GL-B3000 Marble. I'm able to log in via SSH and start the configuration process. Thank you to everyone who worked to make this possible.
@hecatae I have flashed my marble router today using LuCI with the openwrt-qualcommax-ipq50xx-glinet_gl-b3000-squashfs-factory.img version, and it got bricked. I might have flashed it with the wrong file type ? I tried for few hours to boot into Uboot without success!
Can someone help ?
Thanks !
