I was reading about the use of 128bit encryption vs 256 encryption with the consensus generally being that 128 is ‘secure enough’ (source) whilst around 40% faster than 256-bit.
Can anyone tell me if it is possible to modify the .ovpn profile to switch to 128bit from 256?
Also, has anyone tested or found a significant speed difference if using 128bit encryption? As I imagine this would have significant performance implications on devices with limited processing power such as GLI routers.
