Hi everybody!
I have configured on my ar300m 2.261 openvpn. over the eth0-interface a connected host can use the vpn connection.
using wlan, no vpn is used. why?
Regards
Mikee01
Hi everybody!
Regards
Mikee01
Because you are doing something wrong! No idea how to help without much more detail (I have many qualities but mind-reading isn’t one of them).
for sure! okay, let’s roll on…
it is a out of the box configuration with configured wlan and openvpn. lan interface is configured and gives vpn vor the pc that is on the same network using it as gateway. wlan gives inet, but no vpn inet.
