I have an AR750s, OpenVPN client enabled. Until recently everything worked just fine, but lately while the VPN remains enabled, no traffic passes through. I did check the VPN policy and I reset it to force all traffic through VPN.
Any suggestions?
Pls try 3.211 beta3 GL.iNet download center
Maybe just a bug in vpn polices, which we fixed in firmware 3.211
Thanks, this actually worked
Actually, it only worked momentarily. It now reverts back to the original settings
Can you give more details? If you have config files, screenshot and logs that will be very helpful.
