Openvpn bridge client side
#1
is there a way to create a bridge between tun0 and eth0 on the client side openvpn ?? I ask this because the latest firmware version works forwarding but not the openvpn client … I go back to version 3.12 … I tried to create the bridge from the console … it returns is not possible to insert tun0 in the bridge.
Now I use 1. GL-MT300N-V2
Luca
#2
You can refer to this thread. OpenVPN bridging
#3
Thanks for reply.
So you need to change the server-side configuration, I use a cisco RV320 as a server, but I can’t change the low-level configuration of the openvpn server. Is there any other solution?
