I have a problem remotely (as usual) with one of our machine.
It is connected to local wifi and it can ping and connect internet.
But when it’s time to use the VPN client it can’t connect.
It did work well in VPN for a month till last Saturday when they accidentally switched off the WIFI AP from the factory.
We did realize it only yesterday when they asked to modify some parameters on the PLC and we weren’t able to connect.
WIFI was there and ARM300 was indeed connected but the VPN wasn’t able to connect back.
We tried to reset it (hardware, our technician is there today) and re set it up from factory default a few times without any success. WIFI setup it works but when we move to VPN CLIENT… it can’t connect to our server (and actually to any other we tried)
We tested various .ovpn config files, all failed with the same error :
All the config files are working perfectly if tested in my tunnelblick program on my computer but when loaded in the ARM300, it fail.
I checked the log on the vpn server and this is :
===quote log====
local auth failed: no stored password digest found in authcred attributes: auth/authlocal:35,application/app:348,internet/base:1166,internet/base:1175,internet/base:779,omi/omibase:65,internet/defer:102,omi/omimulti:15,omi/omiauth:62,internet/defer:829,internet/defer:746,omi/auth:516,util/delegate:26,auth/authdelegate:308,util/delegate:26,auth/authdelegate:237,util/defer:224,util/defer:246,internet/defer:190,internet/defer:181,internet/defer:323,util/defer:246,internet/defer:190,internet/defer:181,internet/defer:323,util/defer:245,internet/defer:102,auth/authdelegate:61,auth/authdelegate:240,util/delegate:26,auth/authlocal:35,util/error:61,util/error:44
===/quote log===
Can somebody tell me what to do ?
Thanks
D.
