I have setup a openvpn server on a raspberry pi . I have made several config files for different users. When I try and use these config files on android (openvpn app by Arne Schwabe) the connection is made well.
On a windows laptop and OpenVPN client (by OpenVPN) the connection is made well.
I did change the udp port to 1195 on my openvpn server
On my GL.iNet GL-AR300m travel router (firmware 2.261) however i cannot make the connection to the server with the .ovpn file provided.
I'll get this error:
OpenVPN 2.4.3 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 neither stdin nor stderr are a tty device and you have neither a controlling tty nor systemd - can't ask for 'Enter Private Key Password:'. If you used --daemon, you need to use --askpass to make passphrase-protected keys work, and you can not use --auth-nocache. Exiting due to fatal error
any thoughts?
Below is my .ovpn file where I replaced ipadress and key with XXX
client
dev tun
proto udp
remote X.X.X.X 1195
resolv-retry infinite
nobind
persist-key
persist-tun
key-direction 1
remote-cert-tls server
tls-version-min 1.2
verify-x509-name server name
cipher AES-256-CBC
auth SHA256
comp-lzo
verb 1
library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
neither stdin nor stderr are a tty device and you have neither a controlling tty nor systemd - can’t ask for ‘Enter Private Key Password:’. If you used --daemon, you need to use --askpass to make passphrase-protected keys work, and you can not use --auth-nocache.
Using solution of askpass worked for me in getting my ovpn file to work for connecting back to a pivpn server. I just added a line to my config, uploaded it and it worked.
