When I try to connect to my home VPN (OPNsense Firewall), doesnt seem to work, the indicator stays Yellow, and I get no network traffic.
Importong the same config to my laptop’s OpenVPn GUI works jsut fine.
Moedl:GL-SFT1200
Firmware:3.216
.OPVN file:
dev tun
persist-tun
persist-key
data-ciphers-fallback AES-256-GCM
auth SHA3-512
client
resolv-retry infinite
remote fake.net 1194 udp4
lport 0
verify-x509-name “C=US, ST=MY, L=CITY, O=ARCH113, [email protected], CN=ARCH113-VPN” subject
remote-cert-tls server
cryptoapicert “SUBJ:ARCH113.Travel”
auth-user-pass
compress lzo
ca ARCH113_VPN_ARCH113_Travel.crt
tls-auth ARCH113_VPN_ARCH113_Travel-tls.key 1
System Log:
Tue Oct 17 12:31:01 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Tue Oct 17 12:31:01 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: started, version 2.80 cachesize 150
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: DNS service limited to local subnets
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq-dhcp[2866]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain test
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain onion
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain localhost
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain invalid
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain bind
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using local addresses only for domain lan
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: reading /tmp/resolv.conf.auto
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using nameserver 192.168.70.201#53
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: using nameserver 192.168.70.203#53
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: read /etc/hosts - 4 addresses
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq[2866]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Oct 17 12:31:01 2023 daemon.info dnsmasq-dhcp[2866]: read /etc/ethers - 0 addresses
Tue Oct 17 12:31:02 2023 daemon.notice netifd: VLAN ‘eth0.2’ link is down
Tue Oct 17 12:31:02 2023 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Tue Oct 17 12:31:02 2023 daemon.notice netifd: wan (14883): udhcpc: read error: Network is down, reopening socket
Tue Oct 17 12:31:02 2023 daemon.notice netifd: wan (14883): udhcpc: received SIGTERM
Tue Oct 17 12:31:03 2023 user.notice relay: Reloading relay due to ifup-failed of wan ()
Tue Oct 17 12:31:03 2023 daemon.notice netifd: VLAN ‘eth0.2’ link is up
Tue Oct 17 12:31:03 2023 daemon.notice netifd: Interface ‘wan’ has link connectivity
Tue Oct 17 12:31:03 2023 daemon.notice netifd: Interface ‘wan’ is setting up now
Tue Oct 17 12:31:03 2023 kern.warn kernel: [ 3201.511902] [hnat info]wan ip changed, vldclean
Tue Oct 17 12:31:03 2023 daemon.notice netifd: wan (3130): udhcpc: started, v1.29.3
Tue Oct 17 12:31:03 2023 daemon.notice netifd: wan (3130): udhcpc: sending discover
Tue Oct 17 12:31:06 2023 daemon.notice netifd: wan (3130): udhcpc: sending discover
Tue Oct 17 12:31:10 2023 daemon.notice netifd: wan (3130): udhcpc: sending discover
Tue Oct 17 12:31:20 2023 user.info : 1249: gl-vpn-client>> Stop, vpnpath=/etc/openvpn/ovpn0, serverfile=ARCH113_VPN_ARCH113_Travel.ovpn
Tue Oct 17 12:31:20 2023 user.debug : ------ss-redir is not running!------
Tue Oct 17 12:31:20 2023 daemon.info dnsmasq[2866]: exiting on receipt of SIGTERM
Tue Oct 17 12:31:21 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Tue Oct 17 12:31:21 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: started, version 2.80 cachesize 150
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: DNS service limited to local subnets
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq-dhcp[4210]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain test
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain onion
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain localhost
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain invalid
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain bind
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using local addresses only for domain lan
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: reading /tmp/resolv.conf.auto
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using nameserver 192.168.70.201#53
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: using nameserver 192.168.70.203#53
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: read /etc/hosts - 4 addresses
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq[4210]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Oct 17 12:31:21 2023 daemon.info dnsmasq-dhcp[4210]: read /etc/ethers - 0 addresses
