Hi, I´m a new user of GL-iNet products. When trying to configure the OpenVPN Client of the GL-AR150-ext to connect to an existing OpenVPN Server running in a pfSense firewall, I got the following error:
Exiting due to fatal error OpenVPN 2.4.3 mips-openwrt-linux-gnu [SSL (OpenSSL)][LZO][LZ4][EPOLL][MH/PKTINFO][AEAD]library versions:OpenSSL 1.0.2k 26 Jan 2017,LZO 2.09 Error opening file: pfSense-udp-1194-vpnuser1.p12 Exiting due to fatal error.
For some reason the AR150 couldn’t load the certificate file.
The GL-AR150-ext firmware was updated to 2.27.
PS. Using the same configuration files in a Mac or Windows computer the connection goes through successfully.
Any help will be appreciated!
