TECHNICAL DETAILS:
MODEL: GL-SFT1200
FIRMWARE VERSION: 4.3.25 release 2 2025-03-17 11:19:12(UTC+08:00)
SUMMARY: OpenVPN Client module in 4.3.25 will not connect, but does so just fine in 3.216.
ATTENTION: In the logs, there is a warning that appears to be something I can't do anything about.
DETAILS: Awhile back, I bought a GL-SFT1200 (not the one in question) to test an idea for a client (the idea worked). I kept it on the shelf for awhile, but found occasion to use it as a test model in a specific scenario for another client, namely setting up a custom OpenVPN client so that their satellite office's MFP could scan and save files to the file server at the home office. It worked on my test bench and I was very happy! I had my client purchase the same (the unit now in question) and went to the site to set things up. When I did, the unit kept freezing and not connecting. I've found that I'm not even able to use the reset button the same as I did before and I have to perform a factory reset to be able to stop the unit from trying to connect to the VPN again! As a "bandage solution," I swapped units with them (good thing I carry it as part of my toolkit!). That worked. Hooray.
TASK: Resolve whatever bug is causing OpenVPN Client to not connect in version 4.3.25.
WHAT I'VE TRIED:
- Default settings
- Change, "Global Proxy," to, "Auto Detect"
- Turn off IP Masquerading
- Reading carefully the log. "WARNING" found. See Exhibit B and compare to Exhibit A. The configuration is set up to use a tap device both in the client and server configurations.
EXHIBIT A: REDACTED CONFIGURATION FILE (OVPN)
dev tap
auth-nocache
remote vpn.[REDACTED].com 1194 udp
connect-retry 5 5
keepalive 10 60
resolv-retry infinite
mute-replay-warnings
remote-cert-tls server
verb 3
;redirect-gateway def1
cipher AES-256-GCM
auth SHA512
client
tls-client
persist-key
persist-tun
pull
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
EXHIBIT B: REDACTED OPENVPN LOG FROM DEVICE
Thu Apr 17 13:24:35 2025 daemon.notice ovpnclient[6479]: Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA256
Thu Apr 17 13:24:35 2025 daemon.notice ovpnclient[6479]: [RFG-VPN] Peer Connection Initiated with [AF_INET][REDACTED]:1194
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: SENT CONTROL [RFG-VPN]: 'PUSH_REQUEST' (status=1)
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: PUSH: Received control message: 'PUSH_REPLY,route-gateway 172.16.218.48,ping 10,ping-restart 120,ifconfig 172.16.218.210 255.255.254.0,peer-id 1,cipher AES-256-GCM'
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: timers and/or timeouts modified
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: --ifconfig/up options modified
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: route-related options modified
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: peer-id set
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: adjusting link_mtu to 1624
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: OPTIONS IMPORT: data channel crypto options modified
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Apr 17 13:24:37 2025 daemon.warn ovpnclient[6479]: WARNING: Since you are using --dev tun with a point-to-point topology, the second argument to --ifconfig must be an IP address. You are using something (255.255.254.0) that looks more like a netmask. (silence this warning with --ifconfig-nowarn)
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: TUN/TAP device ovpnclient opened
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: net_iface_mtu_set: mtu 1500 for ovpnclient
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: net_iface_up: set ovpnclient up
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: net_addr_ptp_v4_add: 172.16.218.210 peer 255.255.254.0 dev ovpnclient
Thu Apr 17 13:24:37 2025 daemon.notice ovpnclient[6479]: /etc/openvpn/scripts/ovpnclient-up ovpnclient 0 ovpnclient 1500 1624 172.16.218.210 255.255.254.0 init
Thu Apr 17 13:24:37 2025 user.notice ovpnclient-up: env value:daemon_log_redirect=0 X509_1_emailAddress=[REDACTED] script_type=up proto_1=udp daemon=0 SHLVL=1 dev_type=tun remote_1=vpn.[REDACTED].com dev=ovpnclient X509_0_CN=RFG-VPN remote_port_1=1194 X509_1_CN=RFG-VBOX X509_1_C=[REDACTED] tls_digest_sha256_0=[REDACTED] daemon_start_time=1744921474 script_context=init ifconfig_local=172.16.218.210 common_name=RFG-VPN tls_digest_sha256_1=[REDACTED] verb=3 local_port_1=1194 X509_1_L=[REDACTED] link_mtu=1624 trusted_ip=[REDACTED] tls_serial_hex_0=[REDACTED] X509_1_O=[REDACTED] tun_mtu=1500 tls_serial_hex_1=[REDACTED] trusted_port=1194 tls_id_0=CN=RFG-VPN tls_id_1=C=[REDACTED], ST=[REDACTED], L=[REDACTED], O=[REDACTED], OU=Certificate Authority, CN=RFG-VBOX, emailAddress=[REDACTED]
Thu Apr 17 13:24:37 2025 daemon.notice netifd: ovpnclient (6479): sh: 1: unknown operand
