Hi. This is my first post on this forum and I’m looking for help with my GL-AR300M. I just updated its FW to 3.201. Now my OpenVPN connection does not connect. The last line in the system log is
Not really comfortable sending log data due to security and privacy concerns. Sorry. Here are the two relevant log entries:
Mon May 3 12:35:12 2021 user.notice startvpn: start setting local policy
Mon May 3 12:35:25 2021 user.notice startvpn: can’t find tun’s ip, local policy failed
The Internet connection is OK, because without VPN I can reach the internet through the router.
I don’t think it’s a DNS issue because the VPN Server Address in the ovpn file is a numeric ip address, not a text name that needs DNS resolution. Am I missing something?
Has anyone else had trouble with OpenVPN connection after upgrading to 3.201?
Thanks FMS. I’ve already tried the recommended change to the proto line in the ovpn file. In my case it did not solve the problem.
I also tried downgrading the FW to the previous version. I used the manual upgrade feature in the gui (not the one where you boot into bootloader mode).
The FW format check failed.
Next I think I’ll try reloading the latest FW with the bootloader.
