hello, thanks, using ar-750s-ext, firmware 3.215
how to start/change the current openvpn profile via command line and/or cron?
in the gui
in the gui
You may be able to stop the vpn service and load a configuration from cron with the following:
/etc/init.d/openvpn stop
openvpn --config /path/to/openvpnconfig.ovpn
Or in cron just add the following for the command
/etc/init.d/openvpn stop && openvpn --config /etc/openvpn/ovpn0.ovpn
/etc/init.d/openvpn stop && openvpn --config /etc/openvpn/ovpn1.ovpn
